I Have a Raymarine Radar RL70CRC HSB2 2005 last one in production.the chartplotter no longer works on the display when pressing that button, No more interface with my Fishfinder L760CRC I sent it in a Raymarine Service center I was told CPU crashed they have no more parts, Any body can help me. Thanks Nicole
If both plotter works but they have no comunikation
RESET the RL 70 AND L760
This is how it works
press the powerbutton when you have picture press the menu bottom
than systemsetup and than four seconds the menu bottom.
Do this on both plotter normaly after this it works again
If you are having trouble loading charts on your Raymarine E80 chartplotter, there are several things you can try to troubleshoot the issue:
1. Check the chart card: Make sure that the chart card is inserted correctly and that it is compatible with your chartplotter. Some chartplotters require specific types of chart cards, so check the user manual or contact the manufacturer to ensure compatibility.
2. Check for software updates: Make sure that your chartplotter has the latest software updates installed. You can check for updates on the Raymarine website or by contacting customer support.
3. Check the chart source: Make sure that the chart source is set correctly on your chartplotter. If you have multiple chart sources (e.g. internal memory, external card), make sure that the correct source is selected.
4. Check the chart format: Make sure that the chart format is compatible with your chartplotter. Some chartplotters only support certain chart formats, so check the user manual or contact the manufacturer for compatibility information.
5. Check for obstructions: Make sure that there are no obstructions blocking the GPS antenna or interfering with the chartplotter's reception. Obstructions can include tall buildings, trees, and other objects that block the line of sight to the GPS satellites.
6. Reset the chartplotter: Try resetting the chartplotter to its default settings. This can sometimes clear up software glitches or other issues that may be preventing the charts from loading.
If none of these solutions work, you may need to contact Raymarine customer support for further assistance or repair.
You may be able to send it in to Raymarine however you need to call to be sure. The older models are often abandoned and they may not work on them any longer.
I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
I have the same problem. All functions and settings appear to be working OK but no image. After startup time about 3.5 amps are drawm When I turn on power [transmit] amps goes up to 4.5 approx.
I have the scanner head spinning but no target images
I did exactly what you wish to do a couple of years ago. It was a 5 minute job, cut out the same except the new unit needs a little more space behind and it was a plug for plug swap. Works great and swaps data between the matching chart plotter to give chart overlay on the radar Richard
There is a feature in these chartplotters called "Plotter Mode" that is often misunderstood and causes the exact problem you describe.
Press menu.....chart setup.....and scroll to the bottom until you see Plotter Mode in the list of options. It should be set in the OFF position.
If you have more than one display networked onboard check the setting in each one invividually.
What Plotter Mode does is allows the chartplotter system to access range scales not supported on the chart. It is not normally used for map-based navigation but more so for chartless electronic plotting (it can display routes, waypoints and track-recorder breadcrumbs.) open-ocean cruising, or for ultra-precise GPS operations (like a precision anchor drop, finding a very specific location etc. When plotter mode is on you can zoom in to a very, very small working area. The indicator it is enable is the cross-hatch background on the screen, the lack of map information, and the NO CHART DATA watermark on the screen.
