The camera says it requires a mini SD card but my problem is the mini card is too small to fit the slot and the regular SD card is too large.
Thats weird! This is the right size of SD card for your camcorder. http://www.tristatecamera.com/lookat.php?sku=1GBSD80MINI&stsid=CANHG10 Did you try one of the same size?If yes then Did you try an adapter like this one? http://www.nextag.co.uk/INTEGRAL-Micro-SD-Card-1508586241/uk/prices-html?nxtg=16420a280d0a-59E6FEB3CB48EF1E You should get an adapter of appropriate size and place the micro SD card in the adapter and then insert the adapter into the camcorder.
This Tablet Personal Computer [PC] takes Micro Secure Digital [SD] Cards.
To transfer pictures from a Digital Camera to this PC, if the Camera also
takes Micro SD cards, is simply a matter of removing the Micro SD card from the Camera and installing it in the PC's Micro SD Card Slot and then waiting for the PC's AutoPlay function to serve up the photo files stored on the card, which can then be Dragged and Dropped into a photo folder on the PC.
If
the Camera takes SD Cards, then a Micro SD to SD Card Adapter is required so
that the PC's Micro SD Card can fit in the camera before pictures are
taken and then disconnected from the adapter afterwards, for re-insertion in the PC.
If
the Camera takes a different type of Memory Card, then a Multi Card Reader
might be required, which would be connected to the computer's USB Port
and the Memory Card slotted into its matching slot in the Card Reader.
See Acer Iconia Tablet PC Specifications here (or on similar specification pages):
http://www.amazon.com/Acer-A500-10S16u-10-1-Inch-Computer-Aluminum/dp/B004XZL980
USB MULTI CARD READER
MICRO SD CARD TO SD CARD ADAPTER
