BUHEL Helmet Communication System D02 Intercom Logo
k
katie Posted on Mar 01, 2014
Unpair devices i have the D02 but they are not pairing correctly how can I start from the beginning
keith burkill
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 09, 2014
keith burkill
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
323
Points
Hi. Once they are paired you don`t have to do it again. If you power up the two intercoms then press the A button it should link the two. Keith
Unpairing bluetooth devices
Watch tamil action movies online free HD print Quality
  1. Turn Bluetooth on and check the list of paired devices. See Turning Bluetooth on or off.
  2. In the Paired devices section, tap next to the device to unpair.
  3. Tap Unpair.
hope you will find the answer ... also check my movie site
The wheel for scrolling on my M510 mouse does not scroll
Try to unpair and repair the mouse to it's receiver by using the Unifying Software:http://www.logitech.com/pub/controldevices/unifying/unifying250.exe
To unpair the device:
1 - Open the Unifying software
2 - On the Welcome window, click Advanced...
3 - In the left pane, select the device you wish to unpair.
4 - On the right side of the window, click Un-pair, and then click Close. This will remove your mouse or keyboard from the list of Unifying devices and it will no longer work with your computer.
To pair the device:
1 - Launch the Logitech Unifying software.
2 - At the bottom of the Welcome screen, click Next.
3 - When you see the "Restart the device..." screen, follow the on-screen instructions to turn your device off and then back on.
4 - When your device is detected, you'll see a "We have detected your..." confirmation screen. Move the mouse around to see if the cursor moves with it.
If your device connected successfully, click Yes and then Next.
5 - Click Finish to exit the Logitech Unifying Software (or Pair Another Device to pair additional devices). Your device should now be connected.
Try the mouse on a different USB port as well as on a different computer if the issue persists.
Also try to clean the mouse, without opening it, with compressed air.
Unpair device
why? Just pair up the new phone to the device, it should have space for several allowed devices...
Reset blackberry bluetooth
Correct me if I am wrong, but there is no way to reset the bluetooth profile, unless you do a clean factory reset.
if you are having problem with a connected device and you want to reconnect with a new profile, just unpair the 2 device and re-pair
tks
Parrot mki9200
Unpair phone from coonected device as well as unpair phones from devices and try pairing again
Jun 28, 2013 • Cell Phones
1helpful
Even though my H12 is paired and it will dial the last call, I do not have any sound. I do not even hear the initial tone when i turn it on.
unpair it from your device and pair it again or try restarting the device your connecting it too and unpair and pair it again. Hope this works!
1helpful
I have my bluetooth on and have tried to receive files via bluetooth from other phones and from pc and i can pair with other device but not receive files.It says paired but not connected.Is there something...
Sometimes this happens because either you or the other person changes the pairing keys or remove your mobile from his paired list.
It can be solved by unpairing and then pairing again wwith the other device.
Go to settings in your wildfire, Wireless and network, bluetooth. Long press on the device name and select unpair. Also remove your wildfire from the other device's paired list. Then scan for bluetooth devices and pair again. This should solve this problem.
Also, when some device sends you a file via Bluetooth, there is a notification asking permission to receive file. Make sure you click on it and select accept.
Unpair device
Hold down the red and green buttons for 3 seconds while the Parott is powered up. It will erase the last 3 phones
1helpful
2answers
I was paired to one phone, now I need to "unpair" because that's what Verizon told me to do, the phone pairs, but won't connect.
No such thing as unpairing, remember that not all bluetooth devices are compatible. A complete list of phones that are compatible are located on motorola's website, under consumer products, bluetooth. BTW, if you don't know the pin to pair the devices is 0000
Unpairing bluetooth headset without mobile???
You may be having compatibility issue instead of what you suspect may be wrong with both your phone and the Bluetooth headset your friend gave you.
Well, there is no such thing as a Bluetooth headset being permanently locked in to a phone.
As long as there is an open 'visible' Bluetooth connection option and there are devices in range ready to pair, the process to pair starts.
Whenever there are incompatibility issues, pairing two devices using Bluetooth becomes a hassle.
Top BUHEL Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a BUHEL Radio Communication Expert? Answer questions, earn points and help others
