Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Loud buzzing noise
There is a loud intermittent click/buzz coming from the fridge, seems to be at or near the compressor...fridge and freezer are working but the noise is getting worse...is it a relay?
    Sergeant:
  • 308 Answers
Yes that is your relay they are pretty common use your model number to track one down may tag is owned by whirlpool so most local places will have them
Posted on Mar 02, 2014
SOURCE:
  • 290 Answers
SOURCE: Kenmore (253.51399104)side by side making buzzing/humming noise
It will rattle slightly, this is normal. The ones that are burned out will sound like they have gravel in them, you can defininely tell something is wrong.
The problem with diagnosing Kenmore fridges with this problem is that there are different manufacturers. Yours is built by Frigidaire and probably has a Tecumseh compressor. We find more failed compressors with the Tecumsehs than we do with the models that have Embraco compressors. The models with Embraco's generally have more relay failures.
You should not hear the buzz/hum at startup. You will need to replace the compressor, which will be replaced at no charge to you if it is less than 5 yrs old.
If it is older than 5 yrs, you can have it replaced, but it will be almost as expensive as a new fridge. You can buy an aftermarket start device called a 3-in-1. This has a start capacitor built in to give it a little more boost on start up. I don't recommend using them unless it is a short term fix until the compressor can be replaced or if it is out of warranty and there is nothing to lose anyway.
Thanks/Mike
Posted on Dec 06, 2007
milten1
  • 1304 Answers
SOURCE: fridge not cooling, freezer not freezing, buzzing sound
with any luck this is you overload and relay
it is the plug on the actual compressor, this is very easy to replace, if you replace it and it does exactly the same thing its your internal relay and your compressor is done....
Posted on Oct 03, 2009
Testimonial: "thank you...I removed the relay/regulator to find it rattled and found burnt marks inside. I found them online, am waiting its arrival now."
heatman101
  • 43501 Answers
SOURCE: maytag MSD2556AEW; Fridge and freezer not cold
Without actually putting gauges on the system to see what is really going on, I would say that your compressor has failed. There is a good chance that it is something inside that has broken. Turning it off and back on will give it another life sometimes but like youexperienced it is usually short lived.
I assume that you have checked that the condenser fan is running underneath the fridge. Also that the condenser coils are not completely plugged with dirt. These things can also make your firdge od wierd things...
This should give you a couple of things to checkout, but I fear that the compressor is bad and you will need to replace it or get a new refrigerator. If you choose to replace the compressor get a full price quote before the work is done, as it may not be worth doing if you have an older refrigerator.
I hope that this helps you to solve your problem.
Thanks for using Fixya!!
Heatman101
Posted on Nov 25, 2009
SOURCE: 5 yr old Maytag fridge stops working
solve dvb skystr 2TV//MAC:00-08-c9-A2-32-9F/satllit Eutelstw3 7E
Posted on Dec 05, 2009
SOURCE: Maytag Performance PTB1953GR making buzzing noise
refrigerator and freezer not getting cold
Posted on Mar 09, 2010
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Feb 19, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
Buzzing noise near compressor on an Amana refer. PARB1917CSO
I can help , It was the relay , they can blow when they experience a hard start , by replacing it and having the same issue this means the compressor is locked up , they sell a booster for this that can sometimes free the compressor up , its called an rco410 , this part will be your only chance to get your compressor going again. let me know if you have any other questions and tell me how it works out.
Phil
Jan 07, 2009 | Amana ARB1917CSL Bottom Freezer...
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Buzzing intermittent
It sounds like the ice maker. If you don't have the water hooked up, and the ice sensor bar is in the down position, the ice maker assembly will attempt to make ice continuously.
Solution is easy: raise the ice sensor bar until it clicks in the up position. It will lock in this position, and the ice maker will not cycle anymore.
May 04, 2008 | Amana ABB2227DE Bottom Freezer...
most likely the compressor relay is the clicking noise but i think the problem is most likely the compressor is starting to go bad and is lcoking up. if the refig is under 5 yrs old it is most likely still in warranty by amana
Dec 09, 2007 | Amana ABB1927DE Bottom Freezer...
Loud buzzing noise from compressor area and freezer not cold enough
I have a 1.5 year old GE refrigerator and freezer. This unit had not given me any problems until 2 days ago when I constantly heard a loud buzzing sound coming from the freezer. I called GE and Best Buy (bought it there) and asked to troubleshoot this over the phone. They suggested sending a technician over for $100 just for the visit + labor + parts which could add up to hundreds of dollars. So, I researched the web and blogs like this. The answer to my problem was simple. Something that I placed inside the freezer was blocking the air circulation vent. So, I turned off the whole refridgerator and I removed everything from my freezer. For good measure I dislodged some ice and frost that had developed over the vent. I carefully put back everything into the freezer, but this time being careful not to block the vent. I turned on the power and voila! No more buzzing sound!!! I hope this works for you too.
Oct 31, 2007 | Refrigerators
ARB2214CB - Condensor is Noisy
It sounds as if the thermal limit on the compressor is cutting off power to the compressor when it gets too hot. There could be 3 reasons for this. One, the compressor is just bad...should be covered under the 5 year sealed sytem warranty (if its less than 5 years old of course) if this is the case. Two, the thermal overload and start relay assembly is bad. They are mounted directly to the compressor (big round black thing) and can be changed for about$14 in parts (unplug the unit before replacing!) Three, the fan that runs in the bottom near the compressor that cools the compressor and condenser is jammed or not rotating for some reason. It should run any time the the compressor is running. If it doesnt, it need replaced or the compressor will do exactly what you are describing. Hope this helps!
Oct 22, 2006 | Amana ARB1905C Bottom Freezer Refrigerator
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
271 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
