Also has a problem flushing
The roof vent for the toilets is shared. It is the pipe (on the roof) that lets water in the drain system. When clogged, it causes what you have. A garden hose placed in the roof vent (and turned on) may clear the blockage (could be leafs or pine straw or a dead bird). Needs to be cleared... I have used a plumbers snake with 100% success....but you may not have one...so the garden hose suggestion. Be careful on the roof.
SOURCE: toilet downpipe
If you live in an older part of Town, You most likely have an older Sewer, 4-6" clay drain tile leaving your house. This Tiles is in 2-4ft clay sections, layed together with concrete and other ("OLD FASHION TECH") You or your neighbor probably have roots in your old clay tiles creating a blockage. The Roots can enter through the cracks between the old joints of the clay tile in search for a great supply of water!!! Your cheapest and best bet is to call a certified roto-rooter company or someone able to use a roto-rooter rental machine. If you need more info, feel free to ask....Joe
SOURCE: toto toilet, flapper doesn't stay up long enough to flush
One of two things is the problem. First, make sure that you have a tight chain with little slack. If there's too much slack, the flapper won't catch in the passing air to stay up. Second, the flapper is not correct for that style of toilet. You might want to look into purchasing a new Kolby filter that has a removeable cone in the center. Move that cone to 12 o'clock to allow the maximum amount of water to run through the flush valve. If the flapper you have now is flat, it needs to have a cone in the center on the underside.
SOURCE: Kohler Toilet year old do not have flapper. It has stright pipe
This is how it is meant to work!
Short push of lever for small flush, push and hold lever for full flush.
SOURCE: Kohler one-piece has no flushing power
Don't flush more water! Trash the toilet and replace it with a toilet that uses less water and flushes efficiently; practically every manufacturer makes a dual flush or eco model. Spend your money on a good toilet rather than paying for and wasting water every day.
SOURCE: Flush is weakening. Toilet paper won"t flush
Sorry to read about your problem, I hope this helps you out.
i dont think you have toilet issue,
Try this. take a large bucket, like a paint or home depot orange bucket. fill 1/2 way...
put some toilet paper in the toilet. Then pour the water in fast, and see how it flushes. it it does a easy flush then your drain is ok. if its slow, you have a drain issue and not the toilet.
if that the case, then goto the toilet, and clean out all of the little holes, that are around the unit.. where you see the water come out. they can be clogged up. a small type wire like a clothes hanger.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
