Banging when spinning and rubber smell
Machine is banging on fast spin. Rubber seal is rubbing inside door making clothes smell horrid. Have checked inside and belt, bearings, mountings etc are all fine and cant see anything stuck in drum. We are at a loss. Please help.
    Sergeant:
  • 184 Answers
If the basket wabbles like crazy, could have a cracked spider that holds the basket
Posted on Mar 01, 2014
2 Suggested Answers
SOURCE:
caroldon
  • 17130 Answers
SOURCE: machine makes banging sounds and the spin barrel
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Please check the play of the bearings and also the main door seal gasket.
Posted on Jul 18, 2011
Amana washer after smelling burnt rubber and now I'm hearing a banging sound and when the pulley spins it looks like a slight up and Down motion then you hear the bang sound.what do you think it is?
Sounds like the back bearing is at fault, open door & see if you can lift drum with 4 fingers, is there any play, the rubber smell may be the door seal, other that that top support spring may of come adrift, lift lid, or bottom shock is adrift.
Oct 01, 2017 | Amana Washing Machines
Tip
Allways clean your filter on your washer
by cleaning your pump filter at leased once a month will make your washer perform better and last longer. it will stop problems accuring such as (door will not open ) (the machine will not spin on final spin ) (wet cloths) (un even loads) (dirty cloths) (smell & mould ) another good tip is dry off the rubber door seal after use and sprinkle a little talk powder on it this will stop it staining with mould.
on Nov 06, 2011 | Hotpoint Washing Machines
Why does my front loader make a banging noise while spinning?
Ive checked thru the top and back cant notice anythin brohen but when i do spin tbe tub the banging noice is coming from in tbe drum and its pretty wobbley
Aug 28, 2015 | Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Sounds of washing machine upload type kenmore elite total cure plex. when start spinning theirs a strange sound like banging to the wall like blog log loud sounds. wahts the problem with this.
you haven't mention what kind of washing machine you got. Problem with the rubber stand cause the circulation is unbalance. Or might a cloth stock inside. or some part having torn apart for occasional use
Aug 15, 2011 | Washing Machines
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
Oct 07, 2017 | LG WM1812C Front Load Washer
I have a front loading washer - have had for 8 years or so. Began smelling moldy smell - noted little stuff around the holes in the rubber seal around the door. Then I began to pull it back and found mold...
you need to wipe down that part of boot seal after every wash,tide has tablets that you stick in the washing machine and run it through and it removes the smell but it will come back if you don't wipe it down.also if you are using to much detergent that will make it stinky and eat the spider gear and if that happens it's new washer time,you hear a loud banging noise when it's in spin.call your local appliance store and ask them for the pack of tablets,it's like washer magic or something like that,good luck.let me know how you make out
Aug 26, 2010 | Kenmore Washing Machines
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
141 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
