Minolta bizhub 180 Black and White Copier Logo
A
Anonymous Posted on Mar 01, 2014
C220 error code& solution
Error codes and solutions
Tareq Bin Mostaq Mostaq
Level 3:
President:
  • Minolta Master 1,449 Answers
  • Posted on Jul 23, 2014
Minolta Master
Level 3:
President:
Answers
1449
Questions
31
Helped
614243
Points
3628
C0210
Abnormal image transfer voltage
- The image transfer voltage remains more than 100 V continuously for a given period of time while the PC Drum remains stationary.
Konica Minolta Bizhub C220. It has error code C2557 constant paper jam and faint black and white printout
What is error code c2557 on Konica c220?
Check the toner bottle to ensure that it is feeding toner into the sub hopper unit under the bottle. Sometimes users will insert the bottle incorrectly and not lock it properly in place...the lever on the front of the toner hopper for that bottle is moved down to the left to remove and insert the bottle.
Dec 28, 2010
Error code C2557 - Konica Minolta - Copytechnet
1helpful
Konica Minolta bizhub C220 error code C-D010
disable hard discor try to do physicall format in service mode
Error code C4801
no such code for C220
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Error code c-3421 in bizhub c220
Hi
The following site gives error codes for a wide range of printers and their user guides can be obtained as well.
Error Codes Konica Minolta bizhub C220 Code C3421
Your error comes up as follows:-
Code:- C3421
Description:- Fusing heaters trouble (Heating side)
• Detected temperature of the heating roller thermistor/C does not go up a given range of temperature even after a lapse of given period of time at warm up. • Detected temperature of the heating roller thermistor/C does not reach to a given temperature even after a lapse of given period of time after warm up is completed.
Remedy:- 1 Check the fusing unit for correct installation (whether it is secured in position). 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Change fusing unit. 6 Change PRCB. 7 Change DCPU.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Error Code C2152
Transfer belt code was it replaced properly?
2answers
Fusing heater trouble konica c220
You need to change the thermistor on the fuser unit.
Error code EA3226 when I try to scan to e mail on Konica Bizhub C220
this error code is not listed in any of the konica c220 books or on the konica minolta service tech internet site
16helpful
2answers
Please help me for the internal error (C-2553)
i have konica minotla bc352 its giving error c 2553 and megenta background
pl help me
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
