Question about KLH ASW10-120 Subwoofer
Can't find the fuse
Can't find a fuse
    Sergeant:
  • 146 Answers
There is a small plastic plug just above the power cord. Remove it to find the fuse.
http://product-images.highwire.com/4442801/6385-5.jpg
Posted on Jan 07, 2015
SOURCE:
I need a fuse panel diagram for 2011 vw jetta tdi. My radio and rear defrost are not working.
Fuse panel C (dashboard)
Volkswagen Passat B7 - fuse box - dashboard Number Designation in Wiring Diagram Ampere rating [A] Function/component Terminal F1 Fuse 1 on fuse panel C -SC1- 7,5 Headlight DRLs, HID Adjuster motors, Whistler Radar Detector 15a F2 Fuse 2 on fuse panel C -SC2- 15 Airbag control module -J234-, Front passenger airbag -disabled- indicator lamp -K145- 15a F3 Fuse 3 on fuse panel C -SC3- 7,5 Light switch -E1- (T10h/4), Oil level thermal sensor -G266- (T6z/4), ABS control module -J104- (47/8), Instrument cluster control module -J285- (T32/31), Power steering control module -J500- (T6z/1) Data, Engine control module -J623- (T94/87), DSG transmission Mechatronic -J743- (T20e/13), Starter relay 1 -J906- (T7/1), Starter relay 2 -J907- (T9c/1) 15a F4 Fuse 4 on fuse panel C -SC4 7,5 Back-up lamp switch -F4-, High pressure sensor -G65-, Air quality sensor -G238-, Garage door opener control module -J530-, Parallel parking assistance control module -J791-, 16-pin connector -T16- (diagnostic connector), Automatic dimming interior rearview mirror -Y7 -, Left washer nozzle heater -Z20-, Right washer nozzle heater -Z21- 15a F5 Fuse 5 on fuse panel C -SC5- - Not used F6 Fuse 6 on fuse panel C -SC6- - Not used F7 Fuse 7 on fuse panel C -SC7- - Not used F8 Fuse 8 on fuse panel C -SC8- - Not used F9 - Fuse 9 on fuse panel C -SC9- - Not used F10 Fuse 10 on fuse panel C -SC10- - Not used F11 Fuse 11 on fuse panel C -SC11- - Not used F12 Fuse 12 on fuse panel C -SC12- 10 Light switch -E1- (T10h/8), Tiptronic switch -F189, Vehicle electrical system control module -J519- (T52c/1), Selector lever sensor system control module -J587, Electronic steering column lock control module -J764, 16-pin connector -T16- diagnostic connector (T16/16) 30a F13 Fuse 13 on fuse panel C -SC13- 10 Instrument cluster control module -J285- (T32/32) 30a F14 Fuse 4 on fuse panel C -SC14- - Not used F15 Fuse 15 on fuse panel C -SC15- 5 Electronic steering column lock control module -J764- 30a F16 Fuse 16 on fuse panel C -SC16- 5 Data bus on board diagnostic interface -J533- (T20/1) 30a F17 Fuse 17 on fuse panel C -SC17- 10 Steering column electronics control module -J527- (T16l/1) 30a F18 Fuse 18 on fuse panel C -SC18- - Not used F19 Fuse 19 on fuse panel C -SC19- - Not used F20 Fuse 20 on fuse panel C -SC20- - Not used F21 Fuse 21 on fuse panel C -SC21- - Not used F22 Fuse 22 on fuse panel C -SC22- 30 28-pin connector -T28a/22- (right A-pillar), 28-pin connector -T28a/22- (right B-pillar) 30a F23 Fuse 23 on fuse panel C -SC23- 30 Rear window defogger relay -J9-, Rear window defogger -Z1- 30a F24 Fuse 24 on fuse panel C -SC24- 20 Fuel pump relay -J17-, Fuel pump control module -J538- (T10n/1), Transfer fuel pump -G6- 30a F25 Fuse 25 on fuse panel C -SC25- 20 Climatronic control unit -J255- A/C control module -J301- Automatic transmission control module -J217- F26 Fuse 26 on fuse panel C -SC26- 15 Rear lid remote lock key switch -E232-, Compass magnetic field sensor -G197-, Rain/light recognition sensor -G397-, Remote start system relay -J471-, Analog clock -Y F27 Fuse 27 on fuse panel C -SC27 - Not used F28 Fuse 28 on fuse panel C -SC28- 30 Automatic transmission control module -J217- 15a F29 Fuse 29 on fuse panel C -SC29- 20 Vehicle electrical system control module -J519- (T52b/1) 30a F30 Fuse 30 on fuse panel C -SC30- 20 Vehicle electrical system control module -J519- (T52b/42) 30a F31 Fuse 31 on fuse panel C -SC31- 30 28-pin connector -T28/22- (left A-pillar), 28-pin connector -T28b/22- (left B-pillar) 30a F32 Fuse 32 on fuse panel C -SC32- 40 Trunk 12 V Plug [OEM-Fresh air blower control module -J126-], Fresh air blower -V2- 30a F33 Fuse 33 on fuse panel C -SC33- 30 Front seat heating control module -J774- (T8z/3, T8z/6) 30a F34 Fuse 34 on fuse panel C -SC34- 20 Power sunroof control module -J245-, (T16s/1) Sunroof motor -V1- 30a F35 Fuse 35 on fuse panel C -SC35- 30 Driver seat lumbar support adjustment switch -E176-, Front passenger seat lumbar support adjustment switch -E177-, Driver seat lumbar support curvature adjustment motor -V125-, Front passenger seat lumbar support curvature adjustment motor -V126- 30a F36 Fuse 36 on fuse panel C -SC36 - Not used F37 Fuse 37 on fuse panel C -SC37- - Not used F38 Fuse 38 on fuse panel C -SC38- - Not used F39 Fuse 39 on fuse panel C -SC39- - Not used F40 Fuse 40 on fuse panel C -SC40- 40 400W Inverter in Trunk [OEM- A/C control module -J301-], Fresh air blower -V2- 75a F41 Fuse 41 on fuse panel C -SC41- - Not used F42 Fuse 42 on fuse panel C -SC42- 30 Cigarette lighter -U1-12 V socket 2 -U18 75a F43 Fuse 43 on fuse panel C -SC43- - Not used F44 Fuse 44 on fuse panel C -SC44- - Not used Fuse 44 on fuse panel C -SC44- F45 Fuse 45 on fuse panel C -SC45- - Not used F46 Fuse 46 on fuse panel C -SC46- - Not used F47 - Fuse 47 on fuse panel C -SC47- - Not used F48 Fuse 48 on fuse panel C -SC48- - Not used F49 - Fuse 49 on fuse panel C -SC49- - Not used
Fuse panel E (VR6 only)
Panel E is the one in the trunk with your battery on the VR6.
Number Designation in Wiring Diagram Ampere rating [A] Function/Component Terminal F1 -Fuse panel B -SB1- - Not used F2 -Fuse 2 on fuse panel B -SB2- 15 -Engine control module -J623- 87a F3 -Fuse 3 on fuse panel B -SB3- 30 -Reducing agent reservoir sensor -G697- 2, Reducing agent reservoir processing unit, G698- 2 Coolant fan control module -J293-, Wastegate bypass regulator valve -N75-, Positive crankcase ventilation heating element -, N79-Reducing agent reversing valve -N473- 2 87a F4 -Fuse 4 on fuse panel B -SB4- 15 -NOx sensor -G295-2 Oxygen sensor 1 before catalytic converter -GX10-Oxygen sensor 2 before catalytic converter -GX11- 1 Oxygen sensor heater -Z19-Oxygen sensor 2 heater -Z28-1 NOx sensor control module 2 -J881- 2 87a F5 -Fuse 5 on fuse panel B -SB5- 5 -Mass air flow sensor -G70-2 Oxygen sensor 1 after catalytic converter -GX7-Oxygen sensor 2 after catalytic converter -GX8-1 Heater for oxygen sensor 1 after catalytic converter -Z29-Heater for oxygen sensor 2 after catalytic converter -Z30- 1 87a F6 -Fuse 6 on fuse panel B -SB6- 10 -EVAP canister purge regulator valve 1 -N80- 1 Secondary air injection solenoid valve - N112- 3 Camshaft adjustment valve 1 -N205-1 Fuel pressure regulator valve -N276- 1 Exhaust camshaft adjustment valve 1 -N318-1 Fuel pump relay -J17-3 Secondary air pump 87a F7 F7 -Fuse 7 on fuse panel B -SB7- 20 -Ignition coil 1 with power output stage -N70-Ignition coil 2 with power output stage - N127-Ignition coil 3 with power output stage -N291-Ignition coil 4 with power output stage -N292-Ignition coil 5 with power output stage -N323- 1 Ignition coil 6 with p 87a F8 F8 -Fuse 8 on fuse panel B -SB8- 10 -EVAP canister purge regulator valve 1 -N80- 1 Camshaft adjustment valve 1 -N205-1 Exhaust camshaft adjustment valve 1 -N318-1 Reducing agent heater control module - J891- 2 Leak detection pump -V144- 1 87a F9 F9 -Fuse 9 on fuse panel B -SB9- 5 -Brake lamp switch -F-Rear air distribution motor position sensor -G478- 87a F10 F10 -Fuse 10 on fuse panel B -SB10- 5 -Mass air flow sensor -G70-1 Fuel pump relay -J17-2 Automatic glow time control module -J179- 2 87a F11 F11 -Fuse 11 on fuse panel B -SB11- 30 DSG transmission Mechatronic -J743- 1 30a F12 F12 -Fuse 12 on fuse panel B -SB12- 15 Coolant pump -VX20- 1 87a F13 F13 -Fuse 13 on fuse panel B -SB13- 30 -Radio -R-Radio/navigation display unit control module -J503-External multimedia device interface -R215- 30a F14 F14 -Fuse 14 on fuse panel B -SB14- 5 -Motronic engine control module power supply relay -J271- 1, 3 Terminal 30 power supply relay -J317- 2 Engine control module -J623- 30a F15 F15 -Fuse 15 on fuse panel B -SB15- 20 -High tone horn -H2-Low tone horn -H7-Dual tone horn relay -J4- 30a F16 F16 -Fuse 16 on fuse panel B -SB16- 40 -Amplifier -R12- 30a F17 F17 -Fuse 17 on fuse panel B -SB17- 30 DSG transmission Mechatronic -J743- 2 30a F18 F18 -Fuse 18 on fuse panel B -SB18- 5 -Telephone transceiver -R36- 30a F19 F19 -Fuse 19 on fuse panel B -SB19- 5 Vehicle electrical system control module -J519- (T52a/24) 30 Ref. F20 F20 -Fuse 20 on fuse panel B -SB20- 40 Wiper motor change-over relay -J368-Wiper motor change-over relay 2 -J369- 30a F21 F21 -Fuse 21 on fuse panel B -SB21- 40 Secondary air injection pump motor -V101- 3 Auxiliary heater heating element -Z35- (T3hr/1) 2 30a F22 F22 -Fuse 22 on fuse panel B -SB22- 40 Auxiliary heater heating element -Z35- (T3hr/3) 2 30a F23 F23 -Fuse 23 on fuse panel B -SB23- 50 Fuse 32 on fuse panel C -SC32-Fuse 33 on fuse panel C -SC33-Fuse 34 on fuse panel C - SC34- 30a F24 F24 -Fuse 24 on fuse panel B -SB24- 50 Terminal 75 power supply relay 1 -J680-Fuse 40 on fuse panel C -SC40-Fuse 42 on fuse panel C -SC42- F25 F25 -Fuse 25 on fuse panel B -SB25- 40 Terminal 15 power supply relay 2 -J681- 30a F26 F26 -Fuse 26 on fuse panel B -SB26- 50 Automatic glow time control module -J179- (T11a/11) 30a F27 F27 -Fuse 27 on fuse panel B -SB27- 50 Coolant fan control module -J293- 30a F28 F28 -Fuse 28 on fuse panel B -SB28- 40 Vehicle electrical system control module -J519- (T52a/1) 30a F29 F29 -Fuse 29 on fuse panel B -SB29- 40 Vehicle electrical system control module -J519- (T52c/42) 30a F30 F30 -Fuse 30 on fuse panel B -SB30- 40 ABS control module -J104- (T47/1) 30a F31 F31 -Fuse 31 on fuse panel B -SB31- 30 ABS control module -J104- (T47/32) 30a F32 F32 -Fuse 32 on fuse panel B -SB32- 40 Auxiliary heater heating element -Z35- (T3hr/2) 2 30a 1) Only for vehicles with a 3.6L gasoline engine and engine code CDVB
2) Only for vehicles with a 2.0L diesel engine and engine code CKRA
3) Only for vehicles with a 2.5L gasoline enigne and engine code CBUA
WARNING: Terminal and harness assignments for individual connectors will vary depending on vehicle equipment level, model, and market.
Passat, Volkswagen electricity
Jan 16, 2017 | 2011 Volkswagen Jetta
Where is the location of 06 Saturn Ion 2 compressor relay?
Connector 1:
Fuse Block - Underhood Label (2.2L, 2.4L)
Connector 2:
Fuse Block - Underhood Top View (2.2L, 2.4L)
Connector 3:
Fuse Block - Underhood Bottom View (2.2L, 2.4L)
Connector 4:
Fuse Block - Underhood C1 (2.2L, 2.4L)
Connector 5:
Fuse Block - Underhood C2 (2.2L, 2.4L)
Connector 6:
Fuse Block - Underhood C3 (2.2L, 2.4L)
Connector 7:
Fuse Block - Underhood Label (2.0L)
Connector 8:
Fuse Block - Underhood Top View (2.0L)
Connector 9:
Fuse Block - Underhood Bottom View (2.0L)
Connector 10:
Fuse Block - Underhood C1 (2.0L)
Connector 11:
Fuse Block - Underhood C2 (2.0L)
Connector 12:
Fuse Block - Underhood C3 (2.0L)
Connector 13:
Body Control Module (BCM) Label
Connector 14:
Body Control Module (BCM) Top View
Connector 15:
Body Control Module (BCM) Bottom View
Connector 16:
Body Control Module (BCM) C1
Connector 17:
Body Control Module (BCM) C2
Connector 18:
Body Control Module (BCM) C3
Connector 19:
Body Control Module (BCM) C4
Connector 20:
Body Control Module (BCM) C5 (UE1)
2.2L
alt="Object Number: 1438995 Size: MF">
alt="Click here for detailed picture of above image.">
2.4L
alt="Object Number: 1583009 Size: MF">
Fuse Block - Underhood Label Usage (2.2L, 2.4L)
No.
Device
Rating
Description
ECM (2.4L)/TCM Fuse
10A
ECM (2.4L)/TCM
2-3
Not Used
RH HDLP Fuse
15A
Headlamp - Right
5
A/C Fuse
10A
A/C CLUTCH Relay
6-7
Not Used
8
ABS Fuse
10A
EBCM (JM4)
9
ECM/ETC Fuse
15A
ECM
10
EMISS Fuse
15A
EVAP Canister Purge Solenoid, Coolant Level Switch, MAF Sensor, HO2S 1, and HO2S 2
11
IGN Fuse
10A
ICM and PNP Switch (A/T)
12
Not Used
13
TRANS2 Fuse
10A
ECM, Automatic Transmission
14
TRANS1 Fuse
10A
TCM (MN5)
15
BACK UP Fuse
10A
PNP Switch (A/T) or Backup Lamp Switch (M/T)
16
INJECTORS Fuse
10A
Fuel Injectors 1-4
17
FOG LP Fuse
10A
FOG LAMP Relay (T37)
FOG LP Fuse
15A
FOG LAMP Relay (T96)
18
LH HDLP Fuse
15A
Headlamp - Left
19
WIPER Fuse
25A
WIPER 1 Relay
20
HORN Fuse
10A
HORN Relay
21
RADIO Fuse
20A
Audio Amplifier (UZ6)
22
ABS Fuse
20A
EBCM (JM4)
23
RR DEFOG Fuse
30A
REAR DEFOG Relay
24
A/C CLUTCH Relay
A/C Compressor Clutch
Jul 17, 2015 | 2006 Saturn ION 2
I need a fuse panal diagram for the 2013 VW Jetta, my 12 volt power ports are not functioning
Here you go. Fuses on E-box, on left in Engine Compartment
Fuse 1 - Not assigned
Fuse 2 - 10/15A - Engine control unit
Fuse 3 - 5A - Radiator fan control unit
Fuse 4 - 5/10/15A - Lambda probe heater,
Lambda probe 1 heater after
catalytic converter
Fuse 5 - 10A, 20A - Lambda probe heater1,
catalytic converter,
Fuel system diagnostic pump,
Charge pressure control solenoid
valve,
Exhaust gas recirculation cooler
change-over valve,
Crankcase breather heater element,
Vacuum pump for brakes
Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
Throttle valve module,
Activated charcoal filter system
solenoid valve 1,
Continued coolant circulation pump,
Auxiliary air heater heating element
Fuse 7 - 20A, 5A - Ignition transformer,
Fuel pressure regulating valve,
Fuel metering valve
Fuse 8 - 10A - Throttle valve module,
solenoid valve 1
Fuse 9 - 5A - Automatic glow period control unit,
Electric fuel pump 2 relay,
Fuel pump relay
Fuse 10 - 5A - Speedometer sender,
Brake light switch
Fuse 11 - Not assigned
Fuse 12 - 5A - Coolant circulation pump
Fuse 13 - 5A - Water pump
Fuse 14 - 5A - Engine control unit
Fuse 15 - 30A - Voltage stabiliser
Fuse 16 - 30A - ABS control unit
Fuse 17 - 30A - Automatic gearbox control unit
Fuse 18 - 20A - Automatic gearbox control unit
Fuse 19 - 1A - Onboard supply control unit
Fuse 20 - 30A - Onboard supply control unit (AW0)
Automatic intermittent wash and
wipe relay (AW1)
Fuse 21 - 50A - Secondary air pump motor
Fuse 22 - Not assigned
Fuse 23 - 40A - ABS control unit
Fuse 24 - 50A - Trailer detector control unit
Fuse 25 - 50A - Terminal 15 voltage supply relay 2
Fuse 26 - 60A - Automatic glow period control unit
Fuse 27 - 60A - Radiator fan
Fuse 28 - 40A - Onboard supply control unit (AW1)
Fuse 29 - 40A - Onboard supply control unit (AW1)
Fuse 30 - 50A - Terminal 75 voltage supply relay 1
Fuse 31 - 30A - Amplifier
Fuse 32 - Not assigned
Fuse assignment - Interior Fuse Panel
Fuse 1 - Not used
Fuse 2 - 5A - Electronic steering column lock control module
Fuse 3 - 10A - Instrument cluster control module
Fuse 4 - Not used
Fuse 5 - Not used
Fuse 6 - 10A - Vehicle electrical system control module,
Interior ceiling lights,
Tail lights
Fuse 7 - 5A - Fog lamp relay,
Instrument panel and switch illumination dimmer switch,
License plate lamps,
Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
Windshield washer pump
Fuse 9 - 5A - Airbag control module
Fuse 10 - 10A - Right steering column switch
Fuse 11 - Not used
Fuse 12 - Not used
Fuse 13 - 5A - Automatic dimming interior rearview mirror,
Light recognition sensor,
Parking aid control module,
Air quality sensor,
High pressure sensor,
Climatronic control unit,
Tire pressure monitoring button,
Back-up lamp switch,
Left washer nozzle heater,
Right washer nozzle heater,
28-pin connector
Fuse 14 4- 10A - Left steering column switch,
ABS control module,
Light switch,
Airbag spiral spring/return spring with slip ring,
Fuel pump control module,
Fuse 15 - 10A - 16-pin connector (diagnostic connector),
Headlamp range control adjuster,
Auxiliary heater operation relay,
Mass airflow sensor,
Positive crankcase ventilation heating element,
Left front headlamp,
Left headlamp beam adjustment motor,
Right front headlamp,
Right headlamp beam adjustment motor,
Fuse 16 - 10A - Engine control module
Fuse 17 - Not used
Fuse 18 - 15A - Left front headlamp
Fuse 19 - 15A - Right front headlamp
Fuse 20 - 10A - Automatic transmission control module,
Selector lever sensor system control module,
Tiptronic switch,
Ignition/starter switch
Fuse 21 - Not used
Fuse 22 - 10A - Ignition/starter switch,
Converter box,
Alarm horn,
Interior monitoring sensor,
Alarm horn relay,
Fuse 23 - 10A - Vehicle electrical system control module,
Light switch,
Rain/light recognition sensor,
Compass magnetic field sensor,
Fuse 24 - 10A - Vehicle electrical system control module,
Access/start authorization control module
Fuse 25 - 15A - Automatic transmission control module,
Multifunction transmission range switch
Fuse 26 - 15A - Brake system vacuum pump
Fuse 27 - Not used
Fuse 28 - 40A - Auxiliary heater operation relay
Fuse 29 - 1A - Vehicle electrical system control module,
Fuse 30 - 20A - Cigarette lighter,
12 V socket,
12 V socket 2,
Blocking diode
Fuse 31 - 30A - Light switch
Fuse 32 - 20A - Light switch
Fuse 33 - 40A - Heater/heat output switch,
Fresh air blower relay,
A/C control module,
Fresh air blower switch
Fuse 34 - 15A - Left front headlamp,
Fuse 35 - 10A - Steering column electronics control module,
Instrument cluster control module,
Signal horn activation,
Fuse 36 - 25A - Vehicle electrical system control module
Fuse 37 - 15A - Left front headlamp DRL
Fuse 38 - 15A - Right front headlamp DRL
Fuse 39 - 15A - Low beam relay
Fuse 40 - 15A - Towing recognition control module
Fuse 41 - 15A - Towing recognition control module
Fuse 42 - 20A - Towing recognition control module
Fuse 43 - 30A - Front passenger door control module
Fuse 44 - A25 - Rear window defogger relay,
Fuse 45 - 30A - Driver door control module,
Fuse 46 - 30A - Left rear door control module,
Right rear door control module
Fuse 47 - 15A - Fuel pump control module,
Fuel pump relay,
Fuel primer relay
Fuse 48 - 20A - Vehicle electrical system control module,
Fuse 49 - 20A - Climatronic control unit,
A/C control module
Fuse 50 - 30A - Front seat heating control module
Fuse 51 - 30A - Power sunroof control module
Fuse 52 - 20A - Dual tone horn relay
Fuse 53 - 15A - Front seat heating control module
Fuse 54 - 15A - Fog lamp relay
Fuse 55 - 20A - Light switch,
Fuse 56 - Not used
Fuse 57 - 15A - Radio,
Fuse 58 - 1A, 30A - Telephone transceiver
DC/AC converter with socket, 12V-230V
Fuse 59 - 30A - Amplifier
Fuse 60 - 30A - Auxiliary heater control module
Jul 20, 2014 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
Fuse for the alarm system
Here is the full list of fuses for you! and for the car.
catalytic converter
valve,
change-over valve,
solenoid valve 1,
Fuel metering valve
solenoid valve 1
Fuel pump relay
Brake light switch
wipe relay (AW1)
Fuse 1 - Not used
Fuse 4 - Not used
Fuse 5 - Not used
Tail lights
Fuse 11 - Not used
Fuse 12 - Not used
Air quality sensor,
28-pin connector
ABS control module,
Light switch,
Fuse 17 - Not used
Tiptronic switch,
Fuse 21 - Not used
Converter box,
Alarm horn,
Alarm horn relay,
Light switch,
Fuse 27 - Not used
12 V socket,
12 V socket 2,
Blocking diode
A/C control module,
Fuel pump relay,
Fuel primer relay
A/C control module
Fuse 56 - Not used
Hope this helps
--N
May 31, 2014 | 2010 Volkswagen Jetta
Is there a fuse under the hood to open the trunk
Lincoln Town car Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/2002-lincoln-town-car-fuse-box.html
Lincoln Signature Series Engine Compartment Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/lincoln-signature-series-engine.html
There are few related help links for vehicle fuse box.Go through the list and click the required link:-----
2009 Toyota Corolla: Fuse Box Module Removal?
http://howtobyme.blogspot.in/2012/05/2009-toyota-corolla-fuse-box-module.html
1986 Chevrolet Corvette Fuse Box Diagram
http://schematicsdiagram.blogspot.com/2012/11/1986-chevrolet-corvette-fuse-box-diagram.html
1996 Chevy Cavalier Cluster Fuse Box Diagram?
http://schematicsdiagram.blogspot.in/2012/04/1996-chevy-cavalier-cluster-fuse-box.html
2004 Jeep Cherokee Fuse Box?
http://whatisbyme.blogspot.in/2012/05/2004-jeep-grand-cherokee-fuse-box.html
2007 Saturn Outlook Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/2007-saturn-outlook-fuse-box.html
2005 Chevy Impala: Fog light Relay and fuse box diagram?
http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-fog-light-relay-and.html
Freightliner fl112 fuse box diagram?
http://technoanswers.blogspot.com/2012/01/freightliner-fl112-fuse-box-diagram.html
Where is Fuse box located on 2002 Honda Accord?
http://howtobyme.blogspot.com/2011/12/where-is-fuse-box-located-on-2002-honda.html
Toyota Hilux Surf Fuse Box Diagram?
http://technoanswers.blogspot.in/2012/06/toyota-hilux-surf-fuse-box-diagram.html
2006 PT cruiser Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/2006-pt-cruiser-fuse-box.html
Ford inside fuse box diagram showing fuel pump relay?
http://technoanswers.blogspot.in/2012/02/ford-inside-fuse-box-diagram-showing.html
Ford fuel pump fuse layout diagram?
http://technoanswers.blogspot.in/2012/02/ford-fuel-pump-fuse-layout-diagram.html
Saturn Fuse Box Diagram
http://schematicsdiagram.blogspot.com/2012/11/saturn-fuse-box-diagram.html
"Mercedes Benz" Ml 500 "Fuse Box Diagram"
http://schematicsdiagram.blogspot.com/2012/11/mercedes-benz-ml-500-fuse-box-diagram.html
2003 Cadillac Deville DTS Underhood Fuse Box Diagram
http://schematicsdiagram.blogspot.com/2012/11/2003-cadillac-deville-dts-underhood.html
Kia Fuse box?
http://technoanswers.blogspot.in/2012/02/kia-fuse-box.html
Which Fuse controls A/C system on 2003 Ford Taurus?
http://howtobyme.blogspot.com/2011/12/which-fuse-controls-ac-system-on-2003.html
1997 Chevy Malibu Cigarette Lighter Fuse?
http://schematicsdiagram.blogspot.com/2011/12/1997-chevy-malibu-cigarette-lighter.html
Where is Instrument cluster Light Fuse located on 1996 Honda Accord?
http://schematicsdiagram.blogspot.com/2011/12/where-is-instrument-cluster-light-fuse.html
These details will help.
Thanks.
Nov 28, 2012 | 2000 Lincoln LS
2010 lincoln fuse box
Lincoln Town car Fuse Box http://schematicsdiagram.blogspot.com/2012/11/2002-lincoln-town-car-fuse-box.html
FUSE BOX
2009 Toyota Corolla: Fuse Box Module Removal? http://howtobyme.blogspot.in/2012/05/2009-toyota-corolla-fuse-box-module.html
2004 Jeep Cherokee Fuse Box? http://whatisbyme.blogspot.in/2012/05/2004-jeep-grand-cherokee-fuse-box.html
2007 Saturn Outlook Fuse Box http://schematicsdiagram.blogspot.com/2012/11/2007-saturn-outlook-fuse-box.html
Toyota Hilux Surf Fuse Box Diagram? http://technoanswers.blogspot.in/2012/06/toyota-hilux-surf-fuse-box-diagram.html
"Mercedes Benz" Ml 500 "Fuse Box Diagram" http://schematicsdiagram.blogspot.com/2012/11/mercedes-benz-ml-500-fuse-box-diagram.html
Kia Fuse box?
Thanks.
Nov 26, 2012 | 2010 Lincoln MKS
2001 LESABRE fuse schmatics
1986 Chevrolet Corvette Fuse Box Diagram http://schematicsdiagram.blogspot.com/2012/11/1986-chevrolet-corvette-fuse-box-diagram.html
1996 Chevy Cavalier Cluster Fuse Box Diagram? http://schematicsdiagram.blogspot.in/2012/04/1996-chevy-cavalier-cluster-fuse-box.html
----------- 2007 Saturn Outlook Fuse Box http://schematicsdiagram.blogspot.com/2012/11/2007-saturn-outlook-fuse-box.html
-------------- Lincoln Signature Series Engine Compartment Fuse Box http://schematicsdiagram.blogspot.com/2012/11/lincoln-signature-series-engine.html
2005 Chevy Impala: Fog light Relay and fuse box diagram? http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-fog-light-relay-and.html
Freightliner fl112 fuse box diagram? http://technoanswers.blogspot.com/2012/01/freightliner-fl112-fuse-box-diagram.html
------------- 2006 PT cruiser Fuse Box http://schematicsdiagram.blogspot.com/2012/11/2006-pt-cruiser-fuse-box.html
Ford fuel pump fuse layout diagram? http://technoanswers.blogspot.in/2012/02/ford-fuel-pump-fuse-layout-diagram.html
------------ 2003 Cadillac Deville DTS Underhood Fuse Box Diagram http://schematicsdiagram.blogspot.com/2012/11/2003-cadillac-deville-dts-underhood.html
Kia Fuse box? http://technoanswers.blogspot.in/2012/02/kia-fuse-box.html
Where is Instrument cluster Light Fuse located on 1996 Honda Accord? http://schematicsdiagram.blogspot.com/2011/12/where-is-instrument-cluster-light-fuse.html
Thanks.
Nov 23, 2012 | 2001 Buick LeSabre
What fuse is for the clock in my 95 ford taurus
Clock Memory Fuse 8 and Digital Clock Fuse 6 .
A/C Compressor Clutch Fuse 17
A/C Heater Control Switch Fuse 17
A/C-Heater Mode Switch Fuse 9
Air Bag Diagnostic Monitor Fuse 7
Air Bags Fuse 5
Amplifier Fuse 11
Autolamp Dual Coil Relay Fuse 4
Backup Lamps Fuse 5
Blower Motor Speed Controller Fuse 17
Clock Memory Fuse 8
Courtesy Lamps Fuses 6 & 8
Daytime Running Lamps Fuses 5 & 10
Digital Instrument Cluster Fuses 5 & 16
EATC Blend Door Actuator [1] Fuse 17
EATC Blower Motor [1] Fuse 9
EATC Control Module [1] Fuses 5 & 16
Exterior Lamps Fuses 4 & 15
Flash-to-Pass Switch Fuse 10
Hazard Lamps Fuse 1
Heated Oxygen Sensor Fuse 5
Illuminated Entry Fuse 5
Illuminated Entry Module Fuse 8
Instrument Illumination Fuse 13
Keyless Entry Fuses 5 & 8
LCD Dimming Relay Fuse 6
Lamps On Warning Fuse 4
Lamp Out Warning Fuses 6 & 15
Liftgate Window Defrost Fuse 6
Liftgate Window Washer Fuse 6
Liftgate Window Wiper Fuse 6
Light Sensor/Amplifier Fuse 18
Low Oil Level Relay Fuse 18
Main Light Switch Fuse 6
Manual Lever Position Sensor Fuses 5 & 10
Mobile Telephone Transceiver Fuse 11
Police Accessory Relay Fuse 6
Power Antenna Fuse 11
Power Mirrors Fuse 8
Power Windows Fuse 6
Radio Fuse 11
Radio Memory Fuse 8
Rear Window Defrost Fuse 5
Redundant Radio Control Fuse 11
Shift Lock Actuator Fuse 5
Speed Control Amplifier Fuse 6
Speed Control Deactivator Switch Fuse 1
Stop Lamps Fuse 1
Transmission Control Switch Fuse 18
Turn Lamps Fuse 1
Turn Signals Fuse 5
Variable Assist Power Steering Module Fuse 5
Warning Chime Fuse 6
Warning Chime Module Fuse 18
Warning Indicators Fuse 18
Windshield Wiper Control Module Fuse 2
Windshield Wiper Motor Fuse 2.
this will help.thanks.
Feb 20, 2010 | 1995 Ford Taurus
Tail light are not working
fuses under hood
POWER DISTRIBUTION BOX Location Name Amp Circuits Protected A Trailer Tow 50 Fuse 32/Fuse 26/Electric Brake B Fan (Hi) 60 Cooling Fan (CCRM) C Start 60 Starter Solenoid/Fuse 30/Fuse 36/Fuse 2 D Ignition 60 Fuse 6/Fuse 12/
Fuse 8/Fuse 18/Fuse 14/
Fuse 24/Fuse 20/Fuse 21/Fuse 27/Fuse 33 E Rear
Blower/
RAS 60 Rear Heater Blower Motor
Rear Air Suspension F Seat 60 Power Seats G — — Not Used H Fan-Lo 40 Engine Cooling Fans J Power Accessory 60 Fuse 13/Fuse 25/
Fuse 1/Fuse 31/Fuse 37/
Fuse 40/Fuse 7/Fuse 19 K Light 60 Headlamps/Fuse 10/
Fuse 11/Fuse 3/Fuse 9/
Fuse 23/Fuse 29/Fuse 35/Fuse 41/Fuse 17 L ABS 60 ABS Control/Pump Motor Module M Heated
Backlight 60 Heated Backlite/Fuse 16/Fuse 28/Fuse 22 N Fuel 20 PCM/Fuel Pump/CCRM P — — Not Used R PCM 15 PCM Memory S PCM 30 AX4S/Cylinder Identification Sensor/EDIS Module/PCM Power/EGR Control/HEGO's/IAC/
Injectors/MAFS/VMV T Alt./Reg. 15 Generator U Air Bag 10 Air Bag (Dedicated) V Trans. Light 10 Transmission Indicator Light W Fan 10 PCM Fan Monitor X Diode — Hood Lamp Diode Y Relay — RH Trailer Turn/Stop/Hazard Lamps Z Relay — Powertrain Control Module AA Relay — Windshield Wiper Speed BB Relay — LH Trailer Turn/Stop/Hazard Lamps CC Relay — Windshield Washer Pump Motor DD Relay — Windshield Wiper Dynamic Brake/Run
The fuses are color-coded by amp rating.
Fuse Value Amps Color Code 4 Pink 5 Tan 7.5 Brown 10 Red 15 Light Blue 20 Yellow 25 Natural 30 Light Green 40 Orange 50 Red 60 Blue
Mar 14, 2009 | 1997 Ford Windstar
What is the fuse panel diagram for a 1986 Cadillac Fleetwood?
Fuse 1 radio
fuse 2 wiper
fuse 3 gage
fuse 4 turn/back up
fuse 5 electronic brake system module
fuse 6 defog
fuse 7 airconditioning fuel data center climate control panel cluster defog relay
fuse 8 elct. level control ignition
fuse9 cruise
fuse10 phone
fuse11 body
fuse 12 stop/hazard
fuse 13 antenna
fuse 14 elect. level control battery
fuse 15 spare
fuse 16 cigar(ash tray, elect. mirrors, alarm, glove box, LH information center)
fuse17 tail/lic(lamp, photo cell
fuse 18 vacuum pump
fuse 19 deck release
fuse 20 spare
fuse 21 instrument panel
fuse 22 parking lamps
breaker 23 power windows
breaker 24 horn
fuse 25 spare
Check with a Chilton Repair manual just to verify it yourself.
Feb 07, 2009 | 1987 Cadillac Fleetwood
KLH ASW10-120 Subwoofer Logo
99 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
