I have a samsung laser printer model CLP-600N. Ineed a toner cartridge, preferibly black.The starter unit is a CLP-600E.What is the part number for a black or color replacement ? My email # is [email protected]
It is a color laser printer.it has 4 toner cartridge(1)black(2)magenta(3)cyan(4)yellow all cartridge is missing or toner finished.Please purchase full set toner.All toner cartridge has a image sensor.When toner is run out then it is out of work.
There should be a setting or option to do color callibration, or color correction, if it is just printer and it use ink not toner, you have select cleaning nozel.
If the light is solid red: 1. Printer paper is jammed inside your printer. 2. A cover is not being closed properly. 3. Toner cartridge is not inserted properly & need to be reinstalled 4. Toner cartridge is running low 5. No paper in tray 6. Paper inside paper tray is not installed correctly
I've had the same problem with color problems, especially with cyan (blue). I have found that many of the toner cartridges I receive are defective. When I receive a new one, I try it out for a few pages. If the color isn't perfect I return the cartridge and get a replacement. After 1-2 tries, I get one that puts down good color. (A really bad solution I know, but it does get the job done.)
This error can arise when the door on the right-hand side of the printer, the part you open in order to replace the toner cartridges, is not correctly closed. Close the top right-hand section first and then close the door on the right-hand side firmly (slamming it if necessary) and then check that all edges look correctly aligned. That should solve the problem. Incorrect shutting of these parts has always been the cause of this error on our Samsung CLP-600N laser printers and we have several of them.
I fought the "replace transfer belt" message for quite awhile. Then I finally realized I was trying to close the toner cartridge door BEFORE I closed the lid above it. (The printer was close to a wall so I couldn't see the "open and close in this sequence" signs on the cartridge door.) Once I closed them in the proper order, I stopped seeing that message. Janet
