KLH ASW10-120 Subwoofer Logo
A
Anonymous Posted on Feb 28, 2014
Schematic diagrams for ct-150 velodyne - KLH ASW10-120 Subwoofer
My Velodyne CT150 was distorted for a while. Then the sound is completely gone. I checked the speaker, but seemed to be working. What could be the problem?
Define "seemed to be working". Is it or ain't it? A huge clue that something is in distress or having death throes would be distortion.
Either the driver is hot or the amp is shot. You can test the driver by floating it from the amp and attempting to drive it with any other amp channel, or just touch the speaker leads to a small battery. It will click or make static sounds.
Need schematic for velodyne 5 pin din servo amp
Only available from Velodyne.
velodyne at www velodyne com
I have a Velodyne fsx-12 subwoofer. Problem is
Velodyne is the only source for parts and service on this unit.
You will need to contact Velodyne
No sound for Velodyne ct-100 sub woofer
Sounds like a dead amp. You could check the xformer output and the amp IC's with a VOM.
These amps do not cost a lot, about $40.00. and are easy to replace.
Contact Velodyne
Creating a surround sound system
Hi and welcome to FixYa,
Offhand should work more than OK. Even if the 520 is only pushing 75watts per channel, you have 2 X for the front KSB-2.1 (left & right) plus another 75 for the Polk Audio center in addition to 250watts built-in amp of the Velodyne CT-150. What would be better is another pair of KSB-2.1 or comparable for the surround (another 2 X 75 and widening the separation).
Good luck and Thank you for using FixYa. Happy Holidays.
Lost manuel
The Q55 is not a velodyne product
My Velodyne CT 80 powered subwoofer does not power on?
Fuse in amp may be blown or the amp is dead
Contact Velodyne, the replacment amp is not very expensive
1helpful
Velodyne ct 100 to onkyo tx-sr705 how can i connect these two together? the correct way...
hi, on the onkyo check the speaker out , each channel has its own -ev & +ev, each speaker to its appropriate polarity, thats it, its simple.. let me know
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
NOEL
NOEL
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
