This is common problem that how to format Nokia N- Series mobile
Three methods are given below by which you can format your Nokia N- Series mobile
Method 1:
First of all Switch off your mobile then press and hold 3 keys combined
- Green dial key (Call answer button)
- Star key no *
- No 3 key on keypad
then press the power on to switch on the mobile.
- In the process don't leave the 3 press and hold keys
Now wait for message "Formatting" to appear on the screen and release all keys once you see that message.
If it as security code then default security code for Nokia is 12345
Method 2: Hard Format
- Type *#7370# from your dial keys
- It will ask you to confirm that press OK
- It will take some time and your mobile will be formatted & restore settings to default factory settings
- If it as security code then default security code for Nokia is 12345
Method 3: Soft Format
- Type *#7780# from your dial keys
Note: Remember one things by Method 1 & Method 2 this will deletes all your messages, all contacts, photos, notes etc in the phone memory.Your mobile is like a new mobile. So better is first save all your data and then format it. By Method 3 (Soft Format) it only restores your mobile & do not delete your data.
If it helps you Please Click on "Yes" that it helped you
