Question about Jacuzzi - Bathtub - Alcove - Navona - R105917
CAP OFF JET - Jacuzzi - Bathtub - Alcove - Navona - R105917
I just purchased a utlitech 1/2 hp convertible jet pump. When I turn it on it just hums.
I
The hum is the sound created by a motor when it cannot start either because the load is excessive and it cannot do the job or if the start capacitor is bogus.
If cap is good, motor should start immediately upon turn on. Measure cap with cap meter or simply replace it. The capacitance should be the amount indicated on the cap and not more than 10 percent less.
If capacitor is good the pump itself might be frozen. Try running the motor not connected to the pump.
Aug 29, 2015 | Utilitech 1/2 HP Convertible Jet Pump...
The steam comes out of the water reservoir cap instead of the steam Jet Nozzle.
I can only guess since I have never worked on one of these units, but I think you lost a gasket on the cap. Pressure must build in the reservoir before being forced out the nozzle.
Jul 13, 2015 | Tristar SB Steam Buggy Vacuum
Where is the soap dispenser and jet dry dispenser on a Danby countertop dishwasher (with window)
I've got one of these countertop washers at home. The twist off dispenser you're talking about is for the jet dry (at least on mine) and there should be an area on the right side of the door for your soap. Hope this helps!
Jan 31, 2013 | Danby Dishwashers
What oil and how to you check it in a 93 kawsaki 750 jet ski, not engine oil the transmission oil
Your 750 jet ski does not have a gear box. If you are referring to what looks like a filler cap on the front of the motor, that is the generator/flywheel cover and it is a dry compartment and should remain that way.
Jun 11, 2011 | Encore Software Kawasaki Jet Ski...
I have a marble jet bath tub. is there anyway to cap the jet holes, so it is no longer a jetted bath?
You should be able to remove the access panel and just disconnect, and cap the hose that is connected to the pump for the jets and then cap the pump nipple, where the hose connects.
This would likely be easier than trying to locate multiple caps to plug the jet holes in the tub.
I hope this helps you.
Feb 02, 2011 | Jacuzzi - Bathtub - Alcove - Navona -...
GE Triton XL dishwasher, at first I had the left over powder soap issue until I dismantled the lower spray arm and cleaned the nets and removed the rusty particles in the hole in bottom of washer and also...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Sep 25, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
My pump builds pressure to 60 psi but will not go any hire for the shut off what can be the problem
most jet pumps have a pressure switch to regulate cut in/ cut off pressure. Normally 40/60 psi. The pressure switch should be located at the rear of the pump where the wiring enters. First disconnect the power supply to the pump. Remove the cap where the wiring enters. On the inside of the cap there should be a diagram showing how to alter the cut in/ cut off pressure.
Jun 13, 2010 | Jet Plumbing
WHERE DOES JET DRY GO
the turn nob is a cap that you screw out and pour your jet dry liquid in then replace the nob/cap the jet dry will be dispensed automatically.
Sep 29, 2009 | LG Dishwashers
T140E 1978 starts runs at idle, quits on take off. Replaced floats and electronic ign. checked tank cap, fuel flow all ok. Replace main jets with #200. It seems to starve for fuel at take off. Been...
if your model has a amel mark 2 the stand main jet is #200 needle jet #106 pilot jet #20 starter jet #35 the main jet doesn't come into it at take off unless you are pulling 5000 revs or more. i would try raising the needles and checking the pilot jet also try taking of with choke on this will let you know if it is starving for fuel. try the choke one first before pulling the carbs down.
Aug 07, 2009 | Triumph Bonneville Motorcycles
Where does the jet dry go?
Usually in a small port on the door of the dishwasher next to the detergent cup. It should say "JetDry" on it. If not, look for a (usually) gray cap, unthread it, and put the jet dry there. Replace the cap.
Jun 30, 2009 | Dishwashers
Jacuzzi - Bathtub - Alcove - Navona - R105917 Logo
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
