Using HDMI cables, HD cable box & ROKU 3 no longer transmit in HD
SOURCE: Samsung LN-T4061F
To view the captions, all you have to do is turn on the decoder by following these simple steps:
Closed captions should appear within approximately one minute of adjusting this setting. If they do not, review this portion of your television's operating manual or contact the manufacturer of the television set.
Public Television stations do not transmit Closed captioning
SOURCE: HDMI Cable problem
Well, first you might want to try another hdmi connection behind your TV.If it appears to have the same message,you need to check your TV setup and be sure the HDMI video is active.
Secondly,go with the recommendation of the set top box.You will use component video cable to connect from your set top box component video output(Y PR PB) to your TV (Y PR PB) and see if that actually work.If so,just use the cable box for the time being and call your cable company for another cable box to replace this one!
solutiondoct
SOURCE: PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
SOURCE: No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
