Manual 883- rear tire almost rubbing on the right and run light not work left side -help
One possibility is the rear axle isn't aligned so the rear wheel/tire runs true to the axis of the frame. This can be visible with the drive belt not running true on it's sprocket, pulling to one side of the pulley, rather than being about equal spacing on each side of the belt to each side of the pulley.
The other possibility is the rear wheel was removed, and the axle spacers weren't reinstalled in the correct position(s).
The axle spacers are different lengths, and are specific as far as which one goes on the left, which one goes on the right.
