Question about HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E NVIDIA 9100 AM3 Motherboard (610074079576)
Pegatron M2N68-LA power pins
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HEWLETT-PACKARD Master
  • 2,226 Answers
They are number one on the cables are red
Posted on Mar 24, 2014
SOURCE:
What battery is used for CMOS?
CR2032 this is the commonly used battery in the motherboards
May 05, 2014 | HP Pegatron M2n68-la Motherboard...
Tip
Why choose HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E??
Things to be considered in choosing HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E
1. Processor and Memory upgraded
3. I/O Ports and Network
5. Clearing BIOS password
For details you can visit web site www.hpparts.us
on Apr 02, 2014 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
HP Pegatron M2N78-LA having trouble finding a replacement for my motherboard with the same part number, would i be able to put a HP Pegatron M2N78-LA with a different part number into my machine
Before you give up check on ebay. If you do replace just make sure that the physical size is the same and that the replacement uses the same cpu and memory you have now. Otherwise you will be spending much more dinero.
Apr 01, 2014 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
M2n68 la computer wont power on
This is a well known faulty MB & it is not wise to throw good money after bad. Let it go, I know it hurts but let it go.
Jul 13, 2013 | Computers & Internet
M2N68-LA motherboard 12vdc for the cpu fan is only 4vDC.
first change u r smps if no diffrence problem is same then disconnect all chassis fan one by one and check voltage again.
Feb 05, 2013 | ASUS M2N68-LA Motherboard
M2N68-LA (NARRA3-GL8E) Motherboard Manual - ASUS Owners User Manual
There has been a lot of confusion going on around the net. However I find the driver which should work just fine with your model. However the driver is from HP/COMPAQ and the model is M2N68-LA (Ivy8)
You can download the drivers from this link
Documentations will be available here
If you have doubts let me know.
Nov 04, 2011 | ASUS M2N68-AM SE2 Motherboard
Needed to move motherboard to new case because of overheating / ventilation problems - do not know what the power / reset / hdd led leads are for the 9 pin f_panel (new case has each as separate...
Photo of the Asus M2N78-LA motherboard,
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01421635&dlc=en
This photo also shows the orientation (Direction), that the motherboard is sitting in a computer case.
To the very bottom right is the Front Panel header.
The front plastic panel of the computer is the Front Panel.
The area of pins on the motherboard that the cables, (Wires) from the Front Panel connect to, is the Front Panel header. ( F_PANEL )
The Front Panel header, is the black rectangular shaped plastic block, that is sitting vertically on the motherboard.
Has two columns of pins.
4 on the left side, 5 on the right side. Makes it look as though there is a pin missing, at the top left corner.
I'm going to number the pins.
Pins on the Left side starting at the Top, going down;
Pins 1, 3, 5, and 7.
Pins on the Right side starting at the Top, going down,
Pins 2, 4, 6, 8, and 10.
A) Pins 1 and 3 are for the Power On switch. (Power On button)
B) Pins 5 and 7 are for the Power On LED light.
Pin 7 is for the Positive ( + ) wire.
(If the LED light is dim, reverse the wires around)
C) Pins 4 and 6 are for a Reset switch, IF a Reset switch is used. (Reset button)
D) Pins 8 and 10 are for the HarDDrive activity LED light.
Pin 10 is for the Positive wire. ( + )
(If the HDD LED light is dim when operating, switch the wires around)
Pin 2 at the top Right is NOT used. (NC. Not Connected)
For additional questions please post in a Comment.
I am looking at a motherboard manual in PDF file form, for the Asus M2N78-LA motherboard.
Regards,
joecoolvette
Sep 03, 2011 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
I purchased a new case for my computer and I am having problems hooking up the power to the m2n68 la motherboard
ok
here is the manual
it will be difficult to explain here.
Follow the guides in the manual.
cheers uttam
Jan 13, 2010 | ASUS M2N68-AM SE2 Motherboard
Looking for a complete driver pack for the Compaq board M2N68-LA For XP.
http://www.bioticaindia.com/download.php?file=m2n68-la
you need to register first before you can download the file
May 07, 2009 | Computers & Internet
HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E NVIDIA 9100 AM3 Motherboard (610074079576) Logo
193 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Davit Mamyan
Davit Mamyan
Marvin
Marvin
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
