Question about Haier Refrigerators
Defrost timer location
Haier defrost timer location Refrigerator haier hrf-350 plz help reply me soon
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 76 Answers
Check this out for manual: www.manualowl.com/p/Haier/HRF-588FR/Manual/99803
Posted on Mar 07, 2014
4 Suggested Answers
6ya staff
SOURCE:
22yooper
James Helmer
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
freetek
Steve Allison
  • 5569 Answers
SOURCE: hole in freezer of haier refrigerator
The refrigerant used since ~ 10 years is no more dangerous than the one previously used and it is even doubtful that the newer stuff is any better for the ozone layer.
The original coolant could be inhaled without injury as long as one didnt suffocate from a lack of oxygen.
The repair may not be cheap since it will entail the removal and replacement of the damaged coil.
This will require some specialized welding to install.
Using a normal table-top or floor-standing fan to circulate ambient air through the refrigerator with the door(s) open is a safe and fast method for defrosting units that do not automatically defrost.
Just make sure you have some absorbant material in the bottom to avoid water running out of the unit.
Poking the coils with sharp objects can result in the problem you now have or fracture hidden joints that will allow the gas to escape.
Posted on Jul 19, 2008
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Need location of defrost timer
The refrigerator you listed does not have a defrost timer. All defrost and refrigerator functions are controlled on rear of the refrigerator. It's called a mother board. If it s damaged you will sometimes see burns on one of the both sides, but not always. Another problem could be that your defrost element or defrost thermostat is defective. You can see your refrigerator below by putting the model GSS201EMBWW into the model search feature. I am here to help you if you want, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Here is another link here on FixYa that shows the mother board
http://www.fixya.com/support/t230703-ge_refrigerator_stopped_working
Posted on May 28, 2009
How can i operate the temperature of the haier fridge model hrf-660aa
do you hear the compressor come on? can u feel it vibrating? if not? bad relay maybe? is there power from the outlet? may also have a bad cold control thermostat or defrost timer? is ther any heat in the freezer compartment?
Feb 16, 2015 | Haier Refrigerators
Haier defrost timer location Refrigerators hrf-350
Feb 28, 2014 | Haier Refrigerators
Sir i have haier refrigerator hrf 368u its freezer is working making ice but lower portion is not working properly. it is a direct cooling system without frost free
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 28, 2011 | Refrigerators
Why my model HTZ21 JICR55 HAIER IS FROZEN AT THE REFRIGERATOR BOTTON/
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Feb 10, 2011 | Haier Refrigerators
Top freezer is workiing fridge is not haier preference series htp 18 gaa
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 03, 2010 | Haier (HTQ14JABRSS) Top Freezer...
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
How Do i have a Haier HRF-388AE, Do you know how to defrost the Freezer while leaving fridge on?
CAN'T BE DONE AS THE FRIG WORKS OFF THE FREEZER,THE FREEZER MAKES ALL THE COLD AIR FOR FOR FRIG.IF IT'S NOT FROST FREE JUST TURN THE THERMOSTAT OFF TILL FREEZER IS DEFROSTED,IF FROST FREE YOU SHOULD'NT HAVE TO DO ANYTHING,HOPE THIS HELPS-MIKE
Jun 07, 2008 | Haier Refrigerators
Haier HRF-488FR/***
hi there, i noticed your post was in 08 did you find a seal to fit your fridge i have a hrf 488 fr/a and fisher and pykel are looking after them now... they advised be that this model is obsolete now and no longer have parts available.
May 19, 2008 | Haier Refrigerators
Refrigerators Logo
180 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
