Question about Mercedes-Benz Vehicle Parts & Accessories
My radio on my 2000 ml320 won't power on after getting a jump start
    Top Expert:
  • Mercedes-Benz Master
  • 2,044 Answers
More than likely, you jumped it without Grounding the Jumper Cables to the Chassis and burned out a fuse. Never Place both the Pos and NEG to the Battery, Always Ground to the Car with the Cables on newer cars. you can cause all sorts of problems if you don't.
Posted on Mar 03, 2014
SOURCE:
2000 ford tarsus won turn over when trying to
You've either a dead battery or dirty terminals. Clean the terminals at battery and charge it up if needed. First try jumping the battery from another vehicle. If you get power from the jump, then it's what I told you.
Oct 17, 2014 | 2000 Ford Taurus
Why won't the radio/cd player turn on?
Check your radio fuzes usually when the don't turn on the fuze burns out the fuze should be inside of the car on the sides of both doors or on the bottom left hand corner of driver side
Jul 27, 2014 | OEM 1999 Mercedes ML320 Radio / CD Player...
2000 ml320 car wont start after replacing the fuel pump
Either connected the hoses incorrectly, or the new one is deffective, or it blew the fuse.
Apr 27, 2013 | Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome...
Car won't start totally dead no radio, lights
Charge it, or hook up jumper cables, wait a few minutes before you actually try to start it. Make the ground to the running engine the last connection you make.
Jan 27, 2018 | 2000 Chrysler Sebring
I have a 2000 Ford Taurus. My wife left the radio running with the ignition off for a short while. Now the car won't turn over, won't start, won't jump. There is one click when trying to s
The click you are hearing is most likely the start slenoid making contact, however you should short the large wires @ the solenoid to make certain the starter still doesn't run, if so try tapping the starter with a hammer to shift the comutator a litle and try to start. Even if it now starts the starter will continue to give you problems so the proper fix is change the starter
Sep 22, 2012 | 2000 Ford Taurus
Battery went dead, jumped to start, now radio won't play, word CODE came up in little screen above radio, Help
it is most likely that the radio had an anti theft security code activated & until you re activate the code the radio will not work......hope this helps.......cheers.
Sep 08, 2011 | 2000 Mitsubishi Eclipse
How to change starter motor on mercedes ml320
Hello my MB ML320 wont start, only start if I jump it,i change battery but I have same problem it start if I drive for long time but if is park for more than 5 hours it wont start.
Jul 14, 2010 | 2007 Mercedes-Benz ML320 CDI
I need help getting the radio code for my 2000 ml320 vin# 4j6ab54e8ya150540 radio serial Al4910x0909992
hi make a note of your vin number and take it to your nearest dealer he can get it for you please rate this answer thanks
Nov 20, 2009 | 2007 Mercedes-Benz ML320 CDI
Vehicle Parts & Accessories Logo
61 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Jonah Oneal
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
