My first guess is that you have a problem with your electrical system. I would look at the battery cables first. Any corrosion or loose connections could cause these symptoms. Both the positive and negative cables need to be inspected (from end to end). What tests have you run? What have you inspected so far? The condition of the battery and the alternator need to be determined. If you would write back with more information. I will try to help you narrow this down, good luck.
