Often with semi-automatic rim fire rifles, the most common cause of jams/failures to feed are related to improper cleaning. Most of these low-powered rifles utilize a blowback action to fire, and thus require a clean breech and chamber to provide proper obturation of the cartridge. Give your rifle a thorough cleaning, including a detail strip and clean. If you are experiencing other types of stoppages such as failures to extract or failure to feed, you may be experiencing a mechanical issue such as a worn extractor claw, or a weak magazine follower spring.
Change ammo
What type of jam are you experiencing? Stovepipe, double feed, failure to extract? If you can describe the jam, we may be able to help you.
