Question about Lexmark T642 Laser Printer
Lexmark T642: Will not print text files in Linux
Hi
I have a Lexmark T642 and it will not print text files, it just prints random characters at the top of each page and outputs about 10 extra pages each time. I have to convert my text files to postscript and ftp them to the printer, it will then print the postscript fine, but doing this is slow and annoying.
any ideas??
cheers
Tara
    Problem Solver:
  • 13 Answers
Try changing the default print language to PCL
Posted on Feb 06, 2009
    Problem Solver:
  • 5 Answers
You need to download the Postscript drivers from Lexmark site.
Posted on Sep 11, 2008
2 Suggested Answers
SOURCE:
Corysf62
  • 188 Answers
SOURCE: Lexmark T642: Will not print text files in Linux
Sounds like there is something corrupt with the driver or the wrong driver is associated with the printer. Delete the printer from the computer, but leave attached. Download the newest driver directly from Lexmark and execute the download. The computer should then automatically re-install the printer.
please visit the link below to download the correct driver for your printer directly from Lexmark.
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
use the product selector to enter your model number and operating system.
Posted on Oct 04, 2008
T642 wont print unless I cycle the power after a certain amount of time
The error 0x80004005 is a permission issue in Windows. Try running the file as Administrator.
Nov 09, 2012 | Lexmark T642 Laser Printer
I want to add my printer from work to my personal laptop. the t642 is not on the list of printers to add. is it compatible with another lexmark on the list so i can print documents at work
I recommend you use the software you can download from the Lexmark website. Just click on this link: http://bit.ly/c4atAd. Click on the Microsoft, Macintosh, Linux/Ubuntu or Other dropdown to choose the operating system version of your computer. Download and install the software. Hope this helps.
May 03, 2010 | Lexmark T642 Laser Printer
Where to change the setting of a lexmark t642 printer to get the paper printed on both sides
The setting should be on the driver. Once you are ready to print a document just select print then printer options and you should see the option of two sided printing and select the long edge or short edge. If you want to know where in the printer menus is the option, then go to the printer menus then select Finishing Menu then Duplex and just select ON. that should activate the duplex option.
Feb 02, 2010 | Lexmark T642 Laser Printer
Lexmark T642 When printing, LCD displays
this error is a scanner lost lock error and can be caused by the scanner or the logic board. if this error comes up immediately on power up the scanner motor is not initializing by percentages of failure the scanner is approximately 85% the logic board 15% i would change the scanner
Nov 23, 2009 | Lexmark T642 Laser Printer
Lexmark T642 - print is very light
take the cartridges out and clean the spot they go into then clean them off also
Jan 19, 2009 | Lexmark T642 Laser Printer
Realign the print on my Lexmark T642 printer
You can adjust the print registration settings in the Config Mode of the printer. I believe you hold down both the down arrorw and right arrow button when you power on the printer
Jan 12, 2009 | Lexmark T642 Laser Printer
Sep 03, 2008 | Lexmark T642 Laser Printer
Lexmark T642 Missing Character
change font size CPI from 10 to 15
Jul 04, 2008 | Lexmark T642 Laser Printer
Printer stops working until reboot
Could you provide an example of the commands you used?
Apr 28, 2008 | Lexmark T642 Laser Printer
Lexmark T642 Slow Slow Printing
I've had this problem with the Lexmarks's T640 printers connected via USB to Mac OS 10.5.5 machines.
Problem: The Mac OS' default resolution of 1200 DPI for this printer causes the printer to have to rasterize the print job again AFTER it arrives at the printer. The printer does a painfully slow job of this.
Solution: Change the default resolution of your print jobs to "600dpi".
Instructions:
1.)Call up the printer settings menu by starting a print job and clicking the up-arrow next to "Printer" box.
2.)Click on the drop-down list with the name of your application and choose "Printer Features".
Change your resolution to "600dpi". Oddly, I find that "1200dpi Image Quality" is almost as fast.
3.)It might be a good idea to "Save as" this new configuration in the "Presets" menu at the top of your list.
You should notice a tenfold increase in the time it takes the printer to actually produce print jobs now.
Additionally, in the "Color Matching" settings (you can get there by changing from the "Printer Features" settings), be sure that you are using "ColorSync" so your printer isn't having to do any additional processing in that area.
Apr 10, 2008 | Lexmark T642 Laser Printer
Lexmark T642 Laser Printer Logo
287 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
