Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Ali Tarad Posted on Feb 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error C-D36F apear in my minolta c250
That error i found it always on my printer
Boiken Verli
Level 2:
Habit-Forming:
  • Expert 96 Answers
  • Posted on Mar 17, 2014
Boiken Verli
Expert
Level 2:
Habit-Forming:
Answers
96
Questions
0
Helped
68650
Points
142
NVRAM problems better calll KM tech because this kind of error codes need specialez tech and procedure like NVRAM data recovery etc
5 Related Answers
Anonymous
  • 214 Answers
  • Posted on Dec 31, 2007
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Anonymous
  • Posted on May 21, 2008
SOURCE: Konica Minolta Error code C-D351 on a Bizhub C250
Hi
I have come across this kind of problem.
Is your BizHub on the network? If yes, please switch it off completely, and take the Ethernet cable out of the BizHub.
Wait for atleast 30 seconds and reconnect the cable. Now start the printer again and see if the error message goes away.
Hope this helps!
Anonymous
  • 4 Answers
  • Posted on Sep 11, 2008
SOURCE: konica minolta bizhub c250- error code c-0212
Something is going wrong with your LCT!
I am looking into it...
Giamma Giamma
  • 12 Answers
  • Posted on Mar 20, 2009
SOURCE: how do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
chip_reset
Konica Minolta Error Codes and Solutions
  • 210 Answers
  • Posted on Sep 03, 2009
SOURCE: The printer has stopped functioning all together.
C3851: Abnormal Low Temp. (Heater)
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Testimonial: "This is exactly what I needed to do to fix this error. I got it fixed a long time ago but this is the correct answer!!!"
SERVICE ERROR CODE
I am trying to find what that code means. If you want to look for yourself, there are tons of C250 manuals at the following link at Minolta.
http://kmbs.konicaminolta.us/content/support/supporthome.html
Pick category: Office systems
Pick model: C250
2answers
How and where to solve /fix error code C-D301 on bixhub c250
here is the link
http://www.ebookbay.com/ebook/938/konica-minolta-bizhub-c250-sm
if you have any problem contact me.
Download
2helpful
Error code c5201 on konica minolta c250
call a service tech but if you are brave... here is the problem http://www.copytechnet.com/forums/konica-minolta/21588-c252-mainmotor.html
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
2helpful
2answers
How can i get a reset code for my konica minolta C250? I have replaced the drum but C2557 error still appear
hi U can see trouble list [utility +meter counter +stop 00 stop 01 +counter+trouble] U see all error
2helpful
Hi In our office Konica Minolta C250 ,it show message mulfunction. error:- c0206
C-0206 relates to tray 3.
With the copier turned on do the following
Open paper tray 3, remove paper, close tray, open then shut front door, load paper into tray 3 - hey presto!!
If the fault comes back you could have paper stuck behind the tray or have a defective lift up motor.
Regards
Taminol
1helpful
Hi
Hope this helps!
didn't find this code, so dis you read the code correctly and is the model write. you can try troble reset. turn off printer and then on again, holding utility key down. push trouble reset, and reboot again.
3helpful
2answers
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
