My PC is having problem with downloading the Microsoft Net v1.1 framework which is included on the disc, can you help please.
Printmaster 18.1 is not really compatible with Windows 8. Here's a link to a possible solution directly from Broderbund. You can try it, but you might be out of luck.
Printmaster 18 1 Platinum
SOURCE: I have Printmaster 7.0 but it is not compatible
The upgrade path is to Printmaster Platinum 18.1 or Printmaster Platinum 2.0. I'm not sure which is better for you but both are $39.99 from http://www.printmaster.com/ .
The installers for Windows have changed over the years. Your alternatives would be to use a dual boot or virtual computer with XP installed. Win7 Pro and Ultimate allow you to run XP mode free after downloading two programs from Microsoft. All the other options require a licensed (paid) version of XP.
The compatibility mode is available but I'm not sure it will work in this case. You would need to right click on the installer and choose Properties. Then go to the Compatibility tab and chose an older version of Windows (Win98 may be a better choice than XP). Then right click on the installer again and chose Run as Administrator. Then you will need to do the same thing with the actual program.
I hope this helps.
