SOURCE: Part # F5D8233-4 belkin wirless router need software cd
You don't need the cd. It has a connection wizard that helps set it up but you don't need to use that. You need to go to the belkin website and download the manual. That was also on the cd that's missing. Used to be a paper one in the box.
http://cache-www.belkin.com/support/dl/f5d8233-4_v1_manual.pdf
That will tell you how to get setup. For the most part routers run as is right out of the box. You will want to setup the wifi so you will need a SSID name to call it and then turn on the security. WEP or WPA are the usual suspects. Pick a 5 or 10 alphanumeric key. Turn on the wifi. Then you may need to enable dhcp so your computers will get ip numbers from the the router. Most of that is enabled by default on most routers. Wifi usually isn't as it requires more information.
SOURCE: Belkin N Wireless Modem-Router F5D8633 drivers
Just hook it all up, and push and hold the reset button in the back of the router for 10 sec..
Then unplug your internet box, [cable/DSL box] and plug back in,
The internet box will send a IP to your router automaticly.
[If it dont work unplug power from both boxes, then back in but plug the internet box in first..]
done..
if your useing wireless this will not be setup with a password to join, and will be open to neighbors,,
If you want to go to the next step and setup a password to join, you can do this with out the cd also, but get it working first and hit me back
SOURCE: Belkin F5D9230-4 Wireless G Plus MIMO Router setup
To set up the router , you don't need the CD.
you can do it manually.
First make sure that your computer is able to go online through the modem.
If yes then connect the modem and the computer to the router and set up your router.
Click here for step by step solutions
SOURCE: lost installation cd for belkin F5D7234-4 G
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
