SYSTEM REFRESH/RESET OR RESTORE IN WINDOWS 8 You can also used the dell recovery manager to perform the factory restore..
SOURCE: dell inspiron 6400
As far as i remember, you need to press Ctrl + F11 when de Dell screen appears while booting.
I'm not sure though. You could give it a try...
SOURCE: I want to Restore it to factory settings
The best way is with the Operating system disc and do a fresh install, thus wiping all installed programs and data files.
SOURCE: Restore defaults on Dell
Put the DVD with Vista on it in and reboot. Follow the promts on the screen.
SOURCE: Restore Factory Settings on Dell Latitude D620 (refurbished)
Restart your system. As soon as the computer reboots and when you see the blue line on top of the screen with a label www.dell.com that the time that you have to hit ctrl+F11. Once Dell PC Restore appears click on the restore button.
Best of Luck
SOURCE: restore Dell Inspiron M5040 to factory settings
Resetting
a Dell Inspiron to the factory settings allows the user to restore the
Dell Inspiron to the original operating condition as if it was just
taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Step 1:
Before reset any Dell Inspiron laptop, backup your all important data
and programs, otherwise you may lose it. It is recommended to use an
external storage device for your entire data backup, so that you couldn't lose it in any sudden occurring issue...
Step 2: Remove any other unnecessary external drive and restart your Dell Inspiron laptop.
Step 3: Press 'F8' key continue until 'Advanced Boot Options' wouldn't be appear.
Step 4: Use your keyboard arrow key to select 'Repair Your Computer' from the list and hit 'Enter'.
Step 5: Now click 'Next' and login as the administrator account.
Step 6: Click 'Dell Factory Image Recovery and Data Safe options', select your language option and click 'Next'.
Step 7: Click the check box 'Yes, reformat hard drive and restore system software to factory condition' and click 'Next' to start Dell Inspiron reset process...
This
process will erase all your previous changes that have been made to the
Dell Inspiron laptop and reset the configuration settings to factory
setting.
Feel free to get technical assistance for all type of Dell laptop at http://www.vtechsquad.com/dell-support/
