Control board(I think that's what its called. The thing with the vol up/down, power on/off and everything for that front of the tv) broke I was moving it and the screen popped off and broke it so I need to find a new one I can't use my remote turn it on or anything so what is it really called and where can I get a new one
SOURCE: Mitsubishi remote and control panel issue
The control panel circuit board was replaced at a cost of about $40 for the part plus $150 for the house call.
SOURCE: remote control
Do not replaced anithing .filter cover needs to be turn dow. them press reset boton.......
SOURCE: After a move to a new home the screen broke. need
Howdy,
Yes, you can still get them from the Factory. I just checked and Mit's has all items in stock.
The SCREEN- LENTICULAR IS; 491P103030: $171.10. The LENS-FRENSEL IS; 491P104030: $212.80. The Diamond Shield IS; 760D639020: $77.90.
SOURCE: off/on,vol.up/dn,audio,video,mute buttons on
Since the buttons are fine it is definitely a problem with the main board(digital main). The problem is associated with logic control circuitry malfunction which is causing it to send commands to the microprocessor at will. The part is a large board, which is located near the board with all the inputs and has lots of ICs including the microprocessor. I have found a part but just make sure that the part number(934C265001) matches with the one in your set(the number will be printed on the board) before you order. It costs 357$ but they will return you 208$ if you ship them you faulty board, which works out to 148$
http://www.tvserviceparts.com/934C265001.html
