Exercise & Fitness Logo
A
Anonymous Posted on Feb 28, 2014
View wiring would like to see the wiring diagram to connect it right
helix44
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 132 Answers
  • Posted on May 12, 2016
helix44
Expert
Level 2:
New Friend:
Cheetah:
Answers
132
Questions
0
Helped
76728
Points
151
There is a wiring diagram under the motor hood of your treamill usually in a pouch
Right headlight flicker 2007 dodge magnum do i replace the bulb or something else
You do electric circuit testing ,voltage drop testing . Bad connection , ground maybe . Viewing a wiring diagram to know what wires are what .http://www.bbbind.com/tsb-wiring-diagrams-database/
https://www.youtube.com/watch?v=YaYtCVBodpw&t=799s
I was looking for realistic booster equalizer model 12-1953 the speakers wires diagram. Thanks
First, I'm not a Realistic representative.
*** Following is for information only.***
* You can take a small low powered audio source and connect spare speakers to listen for output.
* or a multi meter to check which wires have some sort of drain in reference to each other.
* When volume is set to low you should be able to check for voltage output on wires. Note polarity. Try connecting only left side.
* Connect right side then check again.
* Sorry, unable to find (free) manual download. Every site listed has been blocked or deleted. You may be able to check ebay for manual. But like most old electronics this falls into "Antiques"
* 1987 Ad (lower right); http://fultonhistory.com/Newspaper%2018/Salem%20NY%20Press/Salem%20NY%20Press%201988/Salem%20NY%20Press%201988%20-%200537.pdf
* 1988 Ad; page 60 item 18 floating ground adapter; page 57, https://www.americanradiohistory.com/Archive-Catalogs/Radio-Shack/Radio-Shack-1988.pdf
* Wow, brings back memories of my first TRS-80. The computer that got me started in programing!
* Brick Cell phones!!!
Aloha, ukeboy57
* Additional information (but view at your own risk)
* The problem with "Registration sites" is your not sure if it's the right one or additional fee's required.
* Diagram (requires registration, with Fee?) ; http://www.gobbogames.co/realistic-equalizer-wiring-diagram.html
* Diagram (registration); http://www.falmouthproperty.co/wiring/realistic-equalizer-wiring-diagram.html
* Diagram(registration); http://www.crackthecode.co/realistic-car-radio-wiring-diagram.html
2helpful
2answers
Headlights and tail lights wont turn on bresk lights blinkers wirk fine i just replaced shifter cable the worked fine before
Something didn't get connected right . You would need to view wiring diagram for the headlamp's circuit , check Power & ground's . Do you know how to do that ,using a voltmeter . Free wiring diagrams here http://www.bbbind.com/free-tsb
Electric Testing Techniques You Need to Know
Hoover HWD-20 We want to replace the switch but forgot where to fit the two blue and brown wires in
blue from mains should (connect on the switch ) go to blue wire and brown to brown OVER the switch The switch shouild not connect brown to blue on the powercable . use even a multimeter or
You should know ofcourse where the right points are sometimes there is a little connection diagram on the switch self but not large enough to see or letters on the connectionpoints L and N phase (brown wire) and zero (blue wire) from the motor and electronic assembly if the switch have only 2 contacts then connect blue wire direct to blue wire and brown to brown OVER the switch.
Hoover HWD020 Instructions Product View And Parts Blow Function
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
9helpful
I need a wiring diagram for a 1994 Chevy G20. Where can I get one for free or cheap?
You can go to Autozone.com, and obtain a wiring diagram.
If they have the Repair Guide for the vehicle, they'll have the wiring diagram also.
[I checked, they have the wiring diagram for 1994 Chevrolet G20 3/4 ton Van's]
To view their Repair Guides you have to become a member. It's free to join, and you receive no spam mail.
I have suggested using AutoZone's Repair Guides on here, to those who need access to a free online repair guide. I joined to check it out before recommending, and have never received any spam mail, or have had any problems.
On the home page for AutoZone, go up to the right, and click on -Become a member.
You'll be directed to another page, where you are asked some personal information.
I gave my real email address of course, but that was it.
Write down the user name, and password you have chosen.
After you have filled it out go to the bottom, and click on Submit.
You are instantly a member, and do not have to wait for an email.
Go to the home page again, and this time click on Log In.
After you have logged in go to the upper Left, and click on - Manage My Vehicles
Now go down to the bottom right, and click on - Add a vehicle, in the orange rectangular button.
Click on the Year (1994), then you'll be directed to another page.
Click on the Model (Chevrolet)
Now scroll down, and click on - G20 3/4 ton Van
Click on the Engine size used.
You will now be on the main page.
To the left you will see the heading -
Select a Category
Scroll to the bottom, and click on - Vehicle Repair Guides
Go to the right, and click on - Chassis Electrical - in blue.
Under the white - Select a Chapter - heading to the left, scroll down, and click on - Wiring Diagrams
If you are not familiar with reading wiring diagrams, you may want to view the first two instructional diagrams,
How to read and interpret wiring, and Common wiring diagram symbols.
If your van has a gasoline engine, the wiring diagrams for the 1994 G20's start at the 27th diagram down.
(If I have counted correctly. It is the weekend)
To enlarge the diagram you can either click on Enlarge, or simply Left-click on the diagram itself.
Use the bars on the right side, and bottom to move the diagram around, so you view it fully.
2answers
2004 honda crv
If you can't get a wiring diagram... locate the wiring harness for the lights.... use a multimeter to test the wires....even one of those ice pick type of testers with the light on it will do
have someone step on the brake.... whichever wire has voltage is the brakes. next have them turn on the right turn signal... check for voltage on the other wires... it will of course be off on . do the other side the same way. all you have left is the wire for your running lights.... turn on the parking lights for that. also if i remember right there is a connector already there for the towing package. even if you didn't order that with the vehicle it's likely there. check in the side panel where you store the jack.
Robert
Switch connections
I have a Jenn-air, and the switch for blower and light is on top, front. the switch has 4 connections on the bottom, and viewed from the bottom, the white wire goes at 12 o'clock, the red and brown wires are in the top left corner (paired with the white one) and the black wire is at 6 o'clock, and the blue (double wires) goes in the lower right corner (paired with the black one). If you have a continuity tester, the switch is a dpdt, and white is connected to red-brown (double wires) OR black is connected to blue-blue( double wire).
Hope this helps.
Top NordicTrack Exercise & Fitness Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
