Ok i got a avic-d3 car dvd player but it dont turn on, the fan turn on but the screams and light dont turn on, what i can do? and what can be the problem?
I have a D3 but it doesent ligt up. Plays dvd and all else works but you cant see the picture unless it is held in the light. I have a D3 but it doesent ligt up. Plays dvd and all else works but you cant see the picture unless it is held in the light.
You can't post conmments that contain an email address.
Yellow - Battery
Red - Ignition
Black - Ground
Light Green - E-brake
Purples, greens, whites, and grays - speakers
Purple\white - reverse signal
Blue\white or Blue - amp turn on\ power antenna
Yellow\black - mute wire
Orange or Orange\white - illumination
I had the same problem when purchasing mine open box from CircuitCity. But this is how you do it. Pass it on.
While the unit is turned on, press and hold "MENU" and "Back (Track Left)" buttons simultaneously. Next, push and release reset button. Continue to hold "MENU" and "Back (track left)" until the unit reboots.
Did you hook up the wire harness correctly? Because you are not receiving power to the monitor. check these connections again. Maybe you have the wrong harness. Are you using the one from your car or DVD player? Did you splice the wires together? Do you have a correct color scheme to your vehicles wiring? you may also need to bypass the monitor in order to view the screen while driving (if you're a rebel against johnny law)
Not sure what kind of connections you have, but be sure your unit is recieving good clean power. Try using another 12v constant and possibly a good 12v switched power source. Double check your ground wire as well. The unit may also be broken and might need service.
