Question about Jet Tech Systems F-14 - Multi-Purpose Ware Washer, Compact Counter "
Part number for f-14 dishwasher timer - Jet Tech Systems F-14 - Multi-Purpose Ware Washer, Compact Counter "
    Problem Solver:
  • 25 Answers
SOURCE:
I have a Hobart am 14 with a new pump motor drawing high amps
Search Results
    Dishwasher Electrical Problems - Chapter 6 - Dishwasher ...
    www.appliancerepair.net/dishwasher-repair-6.html
    If the dishwasher is loaded with a lot of food residue, it will need extra rinse cycles .....changes, they will be explained in instructions that come with the new timer. ... If you have an ammeter, the stalled motor will be drawing 10 to 20 amps or more. ... Since the resistance of the heater is very high compared to the resistance of ...
    Pump Repair FAQ - OTP Industrial Solutions
Nov 26, 2015 | Hobart Dishwasher Am-14 Commercial Dish...
Error code E:14 Siemens Dishwasher - stops after 1 min of cycle
It might be helpful if you provide the full model number of the Siemens dishwasher. Most likely E14 error has something to do with water flow sensing. Check if your mains water pressure is ok (tap under sink is fully open). But can provide more details only if you can tell me the model number.
Apr 03, 2014 | Siemens Dishwashers
Where to buy timer motor for my bosch dishwasher SMU2042UC/14
I have had success finding appliance parts on Amazon of eBay, especially if you have a part number or Model number.
Nov 03, 2013 | Bosch Dishwashers
Rotor wont spin
make this tests and fix it. God bless you
Thermal Fuse
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Switch
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Door Latch
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Jul 24, 2013 | Fisher and Paykel Dishwashers
Dishwasher runs for appx 14 min & stops washing half way thru wash cycle. Timer contunies to run. No drain pump out (nothing). Let dishwasher set idle for appx 1 hour and it will re-set. Set timer...
This sounds like something is stuck in the drain pump. You can remove the inner cover to look for obstructions. You have a dual purpose motor it does the both circulating and draining. The blockage is causing it to overheat and trip the thermal protector. You can remove the drain assembly from underneath if you don't find anything from above. There is a video at www.appliancehelponline.com/servicemanual.html that walks you thru most of this. It is a different model but pretty close.If you find no obstructions the motor may be failing.
Apr 08, 2010 | Whirlpool DU840CWD Dishwasher
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 25, 2010 | Dishwashers
Bosch dishwasher model SMU4052UC/14, Won't fill
you need to check the water solenoid valve. if you follow the water line coming into the dishwasher you will find the valve(first spot in the water line with two wires coming from it) if you pull the wires off you should see 110 v when it is trying to fill with water if you do then test the valve for continuity.
May 06, 2009 | Bosch 36 Inch Pyramid Chimney Hood - Black
Will not complete wash cycle
I had a similar problem, except I did not notice a burning smell. I would put my dishwasher on and it would stay on the wash cylce for ever. I had to manually turn the dial to the next cycle.
I had a repairman in and told him I thought it may be the thermostat (from everything I had read online). He dismissd my diagnosis and said it was the timer. He order the timer and came back 2 weeks later and replaced it. It did not solve the problem. He then ordered the thermostats (my Haier ESD102 has 2 of them) and came back 3 weeks later and installed them. That solved the problem!
Timer = $137 CAD (covered by warranty)
Thermostat 1 = $14 CAD
Thermostat 2 = $21 CAD
Jul 19, 2008 | Haier 24 in. ESD100 Built-in Dishwasher
Homark semi integrated dishwasher 01/02-800270
seal gone on bottom of the door
Sep 15, 2007 | Dishwashers
Jet Tech Systems F-14 - Multi-Purpose Ware Washer, Compact Counter " Logo
26 people viewed this question
Top Jet Tech Systems Dishwashers Experts
Robert Marsolais
Robert Marsolais
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jet Tech Systems Dishwasher Expert? Answer questions, earn points and help others
