Sony Bravia 36 40 42 46 50 52 55 LCD Compatible Articulating TV Wall Mount Bracket With Free 10FT Male To Male HDMI Cable Adjustable Tilting Swiveling Wall Mount Bracket for LCD LED Plasma 3255 Inch Flat Screen Panels Logo
Leslie Hirstius Posted on Feb 27, 2014
The word debug is on the screen. how do i take it off?
How do I remove the word debug from the screen?
Laura Harris
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 01, 2014
Laura Harris
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1380
Points
Unplug the power cord of the receiver box for 10 seconds and then plug it back.
How to Enable USB Debugging on Android with Black Screen?
USB debugging must be enabled in order to perform actions on your phone from your computer. This guide takes a look at how to enable USB debugging on Android with broken black screen using a couple of different ways.
- Part 1. Enable USB Debugging on Android with Black Screen Using ADB Command
- Part 2. Enable USB Debugging on Android with Broken Screen Using OTG Cable and Mouse
- Part 3. How to Recover Lost Data from Android with Black Screen
**Part 1. Enable USB Debugging on Android with Black Screen Using ADB Command**
One of the ways to enable USB debugging on your Android phone with a black screen is to use an ADB command. There is a command that you can use with ADB toolkit and that should help turn on the USB debugging option on your phone.
The following describes how to enable USB debugging on Android with black screen through computer.
- Download theADB toolkitfor your computer and extract its contents to a folder.
- ADB requires you have USB debugging enabled on your phone. Since your phone has a black screen, reboot your phone into recovery mode to accomplish this. Press the Volume Down and Power buttons at the same time to enter recovery mode.
- Connect your phone to your computer, open a Command Prompt window in the ADB folder, and type the following command.
adb devices
- You should see your device listed there. Run the following commands one by one.
adb shell
mount data
mount system
- Use the following command to pull the persist.sys.usb.config file from your phone to the PC.
adb pull /data/property/persist.sys.usb.config C:\Users\\Desktop/build.prop" /system/
- Reboot your device using the following command.
adb reboot
You are all set. Your phone will boot up with USB debugging enabled.
**Part 2. Enable USB Debugging on Android with Broken Screen Using OTG Cable and Mouse**
If your phone has support for OTG, then you can actually plug a computer mouse into your phone and use it to navigate around on your device. This way, even if your phone has a dysfunctional black screen, you can still perform various actions on your phone. The following shows how to enable USB debugging on Android with a black screen using a mouse.
- Connect your mouse to your Android phone using the OTG. Make sure your phone supports the OTG feature.
- You will probably need to mirror your phone's screen to your computer, if you cannot see anything on your phone.
- Use the mouse to head into Settings > About phone > Developer options and tap on the Build number 7 times to enable the Developer Options.- Back to About phone section and you should find the USB debugging option. Click on the option to turn it on.
USB debugging is now enabled on your device.
tip
SAMSUNG T100 SECRET CODES
<span> *#06# -&gt; Show IMEI <br />*#9999# -&gt; Show Software Version<br />*#0001# -&gt; Show Serial Parameters <p>*2767*3855# -&gt; Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!!!! but also change IMEI to 447967-89-400044-0, you must use CHGIMEI to restore it)<br /> <p>*2767*2878# -&gt; Custom EEEPROM Reset<br />*#8999*228# -&gt; Battery status (capacity, voltage, temperature) <br />*#8999*246# -&gt; Program status <br />*#8999*289# -&gt; Change Alarm Buzzer Frequency <br />*#8999*324# -&gt; Debug screens <br />*#8999*364# -&gt; Watchdog <br />*#8999*377# -&gt; EEPROM Error Stack <br />*#8999*427# -&gt; Trace Watchdog <br />*#8999*523# -&gt; Change LCD contrast <br />*#8999*544# -&gt; Jig detect <br />*#8999*636# -&gt; Memory status <br />*#8999*746# -&gt; SIM File Size <br />*#8999*778# -&gt; SIM Service Table <br />*#8999*785# -&gt; RTK (Run Time Kernel) errors <br />*#8999*786# -&gt; Run, Last UP, Last DOWN <br />*#8999*837# -&gt; Software Version <br />*#8999*842# -&gt; Test ******** <br />*#8999*862# -&gt; Vocoder Reg <br />*#8999*872# -&gt; Diag <br />*#8999*947# -&gt; Reset On Fatal Error <br />*#8999*999# -&gt; Last/Chk<br />*#8999*9266# -&gt; Yann debug screen (=Debug Screens?) <br />*#8999*9999# -&gt; Software version<br /></span>
on Jan 11, 2011 • Cell Phones
Why does debug shown on my screen?
The word "Debug" is not part of Panasonic TVs. We recommend you contact the source provider so they may properly assist you.
1helpful
The word "Debug is on my tv screen. How do I remove it?
Unplug the power cord of the receiver box for 10 seconds and then plug it back.in job done..
1helpful
Word "debug" on my vizio tv screen
Sounds like firmware corrupted. A firmware update might be necessary. Contract the authorized service center for Vizio.
Gopakumar Gopalan Google
Debug message on far side of Screen
Firmware corrupted. Contact the authorized service center.
Default password of Samsung S3850
*#9998*289# : Change Alarm Buzzer Frequency *#9998*364# : Watchdog *#9998*523# : Change LCD contrast - Only with version G60RL01W *#9998*746# : SIM File Size *#9998*862# : Vocoder Reg - Normal, Earphone or carkit can be selected *#9998*786# : Run, Last UP, Last DOWN If the up Codes doesn't work, you should change *#9998* to *#0. i.e. *#9998*523# change to *#0523#. An other thing that will help is to remove your SIM card. *0001*s*f*t# : Changes serial parameters (s=?, f=0,1, t=0,1) (incomplete) *0003*?# : unknown *0003*?# : unknown
*#9998*377# : EEPROM Error Stack - Use side keys to select values. Cancel and ok *#9998*427# : Trace Watchdog *#9998*785# : RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error. *#9998*778# : SIM Service Table *#9998*947# : Reset On Fatal Error *#9998*872# : Diag *#9998*999# : Last/Chk *#9998*324# : Debug screens *#9998*636# : Memory status *#9998*544# : Jig detect *#9998*842# : Test ******** - Flash the screenligth during 10 seconds and vibration activated *#9998*837# : Software Version *#9998*228# : Battery status (capacity, voltage, temperature) *#9998*246# : Program status *#9998*9266# : Yann debug screen (=Debug Screens?)
*#9998*9999# : Software version
SP-unlock SGH-600 (and also SGH-Sgh-600 *2767*3855# : Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!! ) But also changes IMEI to 447967-89-400044-0. (Doing this is illegal) *2767*2878# : Custom EEEPROM Reset *These codes have been tested with version FLD_2C6 G60SB03X of Samsung SGH-600 Samsung SGH-600 Unlock Codes *#9999# : Show Software Version *#9125# : Activates the smiley when charging. *#0001# : Show Serial Parameters *#0837# : Show Software Version (instructions) *#06# : Show IMEI
DeBug appears whenever
what IE are you using?
the debug will appear when you using IE6. the reason is that most of th web site have activex. IE6 can't handle it. you need to install IE7 sp1.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
