D-Link DSL-2320B Logo
Posted on Jun 11, 2009
I have a Speedstream 5200 modem with a WBR-1310 router connected. Modem is configured in PPOE and router is in access point. This working fine. I want to replace Speedstream 5200 modem with a DSL2320B modem. I can't find how to configure DSL2320b to direct substitution. After PPOE configuration, Modem light for internet connection is ON but modem seem do not give DSN or correct ip address. Can you help me please ? Qsined
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
384
Points
0
Yes,i have a speedstream  5200 modem with a wbr-1310
1helpful
How to setup d-link wbr 1310
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
I have comcast cable net and D-link WBR 1310
Hi, forget about the USB connection since you wanted to use a router for your wireless connection. Contact Comcast asnd make sure they assist you in making your computer connect to the Internet using the ethernet connection because you are going to use the ethernet connection for the modem-router connection. Once your computer is online with the ethernet connection, you can connect your Dlink router to the modem and configure it for Internet connection. There will be more steps before you can use the wireless connection. Just make sure you can get online with ethernet connection first.
2answers
HOW CAN I GET MODEM ACCESS CODE ON SPEEDSTREAM 5100
hello
When you have modem plugged straight into computer, you can access it at 192.168.0.1, should ask for modem access code, (on bottom), then you can click 'advanced' > ppp location and set it for 'on computer'. There may also be a link for technician stats, it will give you info about isp connection. You should / might be able to browse but ISP may need original MAC address of machine (network adapter} you used when 1st signing up. Or if set to PPOE, it would look for name / PW in order to access INternet through ISP.
Anyway, try (after setting PPP on computer) Modem into WAN of router, access router, set PPOE > insert Log-in name / PW and save all settings. Then try homepage, if no, have router "clone MAC address" of the Network adapter you had the 5100 plugged into. Now it should work, even if no <INTERNET> light. ETHERNET light should be constant. Have router use DHCP to address machine independantly of what ISP addresses router, which it will do when modem (having connection confirmed with DSL light)
The other way, PPP location set 'on Modem', means the modem signs into ISP and then it assigns IP address with a timeout around 20 minutes. By getting connection test results when modem is connected to computer, it may seem to make sense, by understanding how ISP knows that modem access code / MAC address, and lets the settings of modem determine if router needs to sign in or not. If PPP is 'on modem', it will be looking for the MAC address of computer, that is why you may need to clone that address into router, so the router can appear as the machine to the modem, than the router assigns net address to computer.
Regards
Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Modem working, Linksey set but can not get interenal on PC
You MUST configure router with instruction supplied by your ISP: PPOE? PPOA? User ID. Password etc...
Connect to router with LAN cable and check configuration with your ISP,
Then follow a check list with this tip to activate your WLAN
Speedstream 4100 does not work with router
you can't.
when the item name as modem/router. it means the main function is modem with added router function.
you can't connect 2 router/modem together. both need access to the internet and IPS for it function correctly.
however, you can connect 1 modem and one router.
Speedstream modem 4200
put the modem in bridge mode and then connect a DSL/cable router to it...you'll have to configure the PPOE if its DSL... Cable is a little easier because there usually is a MAC authientication not username and password...plug dsl/cable router into cable modem...turn both off for about aminute then turn modem on first then router... Be careful most routers with wireless have it enable with no security by default...turn it off or set securty (wirelss that is)
ISP SBC SpeedStream 5100b Modem Causes Install and Connection to Fail
Symptoms * You have a new router, and cannot get online to the Internet. AND * The Setupwizard will detect dynamic IP even though you have a PPoE connection. (Going to router status on the administration page, there is a private IP address on Internet port. 192.168.x.x range.) Cause The SBC DSL modem SpeedStream 5100b, used on new DSL and Yahoo SBC DSL installations since Feb. 2004, causes the NETGEAR router Setup Wizards to fail, and prevents routers from connecting to the Internet. This problem affects many router brands. The modem can be distinguished from the earlier 5100 by a 5th light labeled "Internet". The SpeedStream 5100b's default configuration is "PPPoE on the Modem" ? matching a built-in PPPoE client convenience feature that sends login ID and password to SBC. To Work Around These Issues, Configure the Modem for Bridged Mode Note: In Bridge Mode you cannot to connect to the modem's configuration menu, except by resetting it as described below. 1. Disconnect the router from your network, and connect the computer directly to the SpeedStream modem 2. Open an Internet browser. 3. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 4. Click Advanced. 5. Enter the "Access Code" printed on the bottom of the modem. 6. Click PPP Location. The PPP Location screen appears. 7. Select Bridged Mode (PPPoE is Not Used). 8. Click Save Changes. 9. Connect the router between the computer and the modem. 10. Power off the modem. 11. Power off the computer. 12. Connect the Internet port of the NETGEAR router to the Ethernet port of the modem. 13. Connect the computer to a LAN port on the NETGEAR router. 14. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 15. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 16. Power on the computer. 17. Log in to the router by typing 192.168.0.1 in your browser. 18. When prompted, using lowercase letters, type admin for the user name, and password for the password. Some older routers use 1234 for the default password. If you forgot your router password see http://www.fixya.com/ThreadView.aspx?thid=102081&prdid=252188 19. Use the Setup Wizard to connect to the Internet. To Reset the Modem To Enable Access to the Configuration Screen 1. Disconnect the computer from the modem. 2. Power off the modem. 3. Power off the computer. 4. Connect the Ethernet port of the modem to the computer Ethernet port. 5. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 6. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 7. Power on the computer. 8. Open an Internet browser. 9. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 10. Click Advanced. 11. Enter the "Access Code" printed on the bottom of the modem. 12. Click PPP Location. The PPP Location screen appears. 13. Select PPPoE on the modem. 14. Click Save Changes. 15. At the login screen type in your SBC member ID and password (which is usually the primary email address on the SBC DSL account and the password for the primary email address). 16. Click Connect. * If successful, a screen appears reading "You Are Connected", and the Internet light goes solid green. * An error will display if the username or password is invalid. * If there are other problems the message "The DSL connection is down" appears.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
