Car Audio & Video Logo
Anonymous Posted on Jun 11, 2009
CDX-SW200 plays the stereo but not the CD's
I installed this unit into a 1997 sebring convertible with an OEM power amp. I installed the wiring kit as instructed. I put in a cd and it cycles through as if playing and there are no error code. but there is no sound. The radio works great so I know the amp and wiring is okay. This unit worked great in my daughters Tempo but it sat removed for 8 months or so. I have reset the unit to no avail. I did have the faceplate apart and cleaned the buttons because my daughter had spilled pop on it and made the buttons all sticky. Any suggestions?
  • Anonymous Jun 11, 2009
    I do have the amp remote wire not attached to anything. I'll switch it up. The power antenna goes up when the radion is engaged but not when the cd is engaged. Do you have a color code chart for the chrysler to show what color does what? Thanks for the tip.
    I don't have any place to connect the blue/white power amp wire coming off the stereo's harness to connect to the oem wiring.
kenw392
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Sony Master 2,226 Answers
  • Posted on Jun 11, 2009
kenw392
Sony Master
Level 3:
Renaissance:
Answers
2226
Questions
Helped
474070
Points
4986
Sounds like you connected the amp turn on lead to the power antenna wire coming from the deck, so the amp turns on when you have the radio on, but turns off when playing cds. you need to connect the amp turn on lead to the amp remote wire.
1helpful
1997 Chrysler Sebring JX Convertible, electric top not working. Steps to troubleshoot?
1997 Chrysler Sebring JX Convertible electric top not working Steps to...
http://www.bing.com/videos/search?q=1997+Chrysler+Sebring+JX+Convertible%2c+electric+top+not+working.+Steps+to+troubleshoot%3f&FORM=HDRSC3
5helpful
What is the wiring color code for a sony cdx-sw200
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope that is what you were asking for.
I just purchased the Sony CDX-SW200 from a pawn shop and noticed that it doesn't have a red wire attached to the wiring harness coming from the radio? Is this right? Is there supposed to be a red lead...
you bought it from a pawn shop --and you wired it up so you have some sort of wiring instructions -yes it could have the wrong harness for your application but the correct one for some other
1helpful
I want to install a Sony CDX-SW200 cd player in my car and need to find a wiring diagram. Where can I find one?
If you buy a wiring harness from this guy he will send you a wiring diagram. Copy and paste the web address.
Here you go bud:
http://cgi.ebay.com/SONY-wire-WIRING-Harness-XPLOD-XR-CA430-CDX-MP30-sn6_W0QQitemZ200417888633QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea9d64979
1helpful
Need a wiring diagram to install cd player
If you buy a wiring harness from this guy he will send you a wiring diagram. Copy and paste the web address2_bing.gif.
Here you go bud:
2helpful
Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
SONY CDX-SW200 only tunes into odd frequencies?
Not unless he unit is capable. I know that Cadence made their decks with this feature, and I haven't seen anyone else as of a year ago.
Can't figure out how to change the time
Press DSPL for 2 seconds
Press the + or - volume buttons to set the hour
press SEL
Use the volume buttons to set the minute
Press DSPL
Sony compact disc player initializing
Have you tried pressing hte RESET switch?? It's behind the removeable front of the stereo, use a biro or something and hold it in for a bit.
Failing that, check that there isn't a CD already in it, could be a dodgy CD?
2answers
Amp goes to protect mode only on cd play
Do you get adequate bass on the radio, or is it a bit quiet on the low-end?
Top Sony Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
