If the dryer has dual or triple heating elements, one element, or the relay controlling one element, could be open circuit, ( failed). mostly likely is a failed heater element. The elements work together or separately to combine the heat settings. there could be a high and low element, that do the different ranges. it could be that when it is on medium or high, it's really a lower combination of heat, and it may not be easy to observe, but on the low settings, the chosen element is completely open and failed and provides not heat at all. if medium and high are really low and medium, and low and medium-low is really nothing, then 1 element is probably open circuit. ( failed).
Sound to me like you need to check the vent for proper air flow. Make sure the pipe to the wall aint kinked. Take it apart and clean it up real good. My homemade crappy movie;
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: dryer doesn't dry clothes. seems to run on low heat.
Make sure dryer is unplugged. Take the back off and you will see two heater exchanges and probably the element. One of those heat exchangers is for hot setting. When you find out which one go to nearest electrical shop with it and order. I reckon thats what your problem is. I've changed mine and everything was alright.
SOURCE: Dryer Heats on High all the time
I don't think it is the heating elements. You have checked out all the important stuff. Is there power coming from the controls on medium and low. It sounds like this is the problem.
SOURCE: Frigidaire dryer heats but clothes not drying
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
SOURCE: replaced element and now dryer too hot - vent is clear
Hi, Check the element again. It sounds like the element has relaxed and shorted out against the metal housing. The squeak might be the rear bearing cup. You can check and see if it needs grease while you have the drum out.
I hope this helps you. Please let me know.
Thanks
Vic
SOURCE: gas dryer not heating
Check the following to address this issue.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is
probably with defective coils (black, located on top of the gas
valve). It is recommended to replace all coils (usually two or
three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not
letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer
overheats, in which case the dryer will either not run at all or
stop heating. The fuse is usually located on the vent duct, inside the
dryer. A blown fuse will show no continuity when measured with a
meter. Before replacing the fuse, make sure the blower wheel is not
broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a
hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found
defective.
Note: Igniters are very fragile and break easily. It is recommended
to handle the igniter only touching the ceramic part of it (usually
white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
