You can use the hardware restore button on the Polycom HDX system to reset
the system in one of these ways:
• Restoring configuration-Restores the configuration, which resets most
system settings to default values.
• Factory restore-Completely erases the system and restores it to the
software version and default configuration stored in its factory partition.
If you follow this procedure while a USB storage device is connected, the
system restores from the USB device instead of the system's factory
partition.
The restore button is on the front of the Polycom HDX 9000 series system, as
shown in the following figure.
The restore button is on the front of the Polycom HDX 8000 series, Polycom
HDX 7000 series, and Polycom HDX 4000 systems, as shown in the following
figure.
The restore button is on the left side of the Polycom HDX 4500 system, behind
a wire mesh screen, as shown in the following figure.
Use a paperclip to press the restore button through the wire mesh covering
that side of the system. to reset the HDX Series system we can press the restore button over 15 second.
SOURCE: polycom vsx 7000
no the power supply is propreitory( has multiple voltages) & is not advisable, u could blow up ur expensive confeencing equipemt.polycom has designed it in that manner!!
SOURCE: forgot the polycom VSX 7000 password - how to reset
The polycom didn't allow for numbers, only letters.....
How do I do password recovery in this case?
SOURCE: Polycom 7000 series System Settings
On the home screen, press the help button... there you will get the system option..... .. access the system settings through that...... then go to admin settings-> general settings -> home screen settings...... and select system there to get back the system option on the home screen ......
SOURCE: I have polycom 7000 with
Verify the uplink / download bandwidthon the broadband link.Broadband link do not have symmetrical upstream/downstream speeds. Perform test to verify.
Try non-peak hrs.
Check if latency is consistent.
