SOURCE: can i download the installer of HP Deskjet 1280
I need to install an HP Deskjet 1280 printer and i haven´t got the disc for installation...
SOURCE: problems printing with HP Deskjet 1280
When I printed powerpoint documents on a hp deskjet 1280 it failed to print lines. I found that this problem could be solved by changing the transparency attribute of the line to 50%. The transparency attribute of a line or shape can be found by clicking on the sequence format/shape-outline/more-outline-colours/transparency at the top of the screen
regards
Graham Pratten
SOURCE: HP DESKJET 1280
I had this problem too and found that the rear cover (the one that you remove to clear a paper jam) was not correctly fitted and locked. After resetting the vover and fully locking it worked! Try it.
SOURCE: hp deskjet 3325 light flashing have turned device
no problems
:just go ahead and take out the power cable when the printer is still on
:nw press and hold the power button fr 30 seconds
;while holding the power button,plug back the power cable
:nw u will be able to work well
