Would probably need to start with a pinout for the camera to start then if anyone has an app I mind that might run the camera unless you could run the original camera driver somehow I dunno just thinking dont really know how it all works together
Webcam is actually just a USB connection. Shouldn't need a hardware driver for modern OS. There are generalized apps out there to encode MPEG or AVI, ect. video, but they don't need to be hardware specific. That's where a "standard USB imaging device" driver usually comes in.
Leads are: +5V, Data-, Data+, Ground.
Here's image of a typical pinout to cam ...hope this helps.
SOURCE: how to fix and install the built in microphone of my acer laptop aspire 4720z
If the sound has worked on this machine after the new hard drive was installed, then all you need to do is a system restore from the start menu, acessories/system tools. You may need to go back a couple of restore point in order to get it back, but this should do the trick. If it hasn't worked since the new hard drive was installed, then ou will need to go to the manufacturer's support site and download the drivers.
SOURCE: my sony vaio webcam not working
if you remember the date on which it was working with webmax you can try windows vista system restore feature and restore the system back to the date it was working on
here is an helpfull link
http://www.bleepingcomputer.com/tutorials/tutorial143.html
further Queries are welcome
SOURCE: webcam driver open failed chicony 2.0
ur webcam driver is not suitable for win. 7
plz try it to install in program compatibilty mode
SOURCE: Acer Aspire 5516 laptop - no webcam?
There is not a webcam, although there a a placeholder that looks like one.
