On some cameras this means a slow shutter speed and that the picture may come out blurry because there's not enough available light for a faster shutter speed to get an acceptably sharp picture.
The model indicated uses what is called a Optical Light Engine, it is a very expensive part and likely is your problem---not much else will cause this trouble.
Make sure that the batteries in the camera are good and turn it on. Is there a light that comes on to let you know that the camera has power and is ready when you press the power button? Does that light come on and what color is it?
If the light ends up green, then you know the batteries are good and the camera is functioning properly and is ready to take a picture. If this is the case, then after you turn it on - look on the back of the camera for the focus zoom in and out buttons. Sometimes they look like a switch that you can rock right or left. Press the switch and look through the lens. Does press the switch or arrows in either direction clear up your view and allow you to see anything? Are you looking through the lens hole or are you using a small screen to view on the back of the camera? If you are looking at a screen on the back of the camera and that screen is black - it means that you dont have the exterior view option turned on in the cameras settings. Sometimes there is a button labeled "view" on the back of the camera to alternate from the exterior view screen on the back of the camera and using the lens hole view at the top. Press that key to make the view screen turn on. If this option is not turned on yet, press the menu key on the camera and use the arrow keys to scroll through the option choices until you find the image preview choices and turn this option on. Then save this choice and close the menu features to see if it comes on.
If you are not getting a power indicator light when you turn the camera on, then replace the batteries. If the light comes on and its something other then green and steady - (like red and flashing) check your camera manual to see what this indicator means. Some cameras show a red light that is flashing when you turn them on to indicate that the memory card is full. Some camera have a red light that is steady to indicate that the battiers are almost out of power and they will show a picture on the digital to indicate how much power you have left before they shut down. Each model camera is different according to the options it came with.
The camera may be set to do a multiple exposure and you must take the camera off this setting back to normal mode to remedy this. 1. Look at the top of the camera from the back - on the far left is the knob with the BKT, FLASH, and ISO buttons. On the bottom of the outside of this knob there is a small ring and also a small black unlabeled button to the top left of the knob. 2. Press and hold the small button 3. Turn the ring until it shows the "S" setting
Then fire the shutter - the camera should operate as normal and advance the film after the shutter firing. If it still does not, then your film advance motor may be bad and need to be replaced or repaired.
I'm guessing you have a delay set (people will use this on a tripod). The small button on the top left (next to the flash control) will solve your problem I think.
HA, I got the exact same symptoms on my C5050!!! First the yellow light flashes for 10 seconds then the green one flashes. I believe the internal fuses are blown, there are 2 and they are surface mount so they are like 2x2mm so they are SMALL. Im going to have to jump them with a blob of solder on top. It is useless in its present state
Hi! henori, This set is out of convergence. Go to your menu button on your remote, press it, then find convergence and follow the directions for adjusting the convergence.
Check that you are still taking picures by connecting to the computer or looking at the memory card elsewhere[through a card reader for example.
Want to establish with this a CCD problem or a Firmware problem.
Come back
