Error 91-125 on a Beta SP UVW 1800 is a diagnostic code indicating a problem with the audio channel 1 input. The error message "appears like a feedback on audio channel 1" suggests that there is a signal present on audio channel 1 even though nothing is connected to it. This could be caused by a malfunctioning input or a problem with the internal signal routing.
Here are some steps you can try to troubleshoot this issue:
- Check all audio inputs and outputs to ensure that nothing is connected to audio channel 1.
- Disconnect all cables from the Beta SP UVW 1800 and power it off. Wait for a few minutes and then power it back on.
- Check the audio routing settings in the menu of the Beta SP UVW 1800 to ensure that audio channel 1 is not being routed to an unexpected location.
- Inspect the audio channel 1 input for any damage or corrosion.
- Try a different audio cable or input device to rule out any issues with the current cable or device.
- Check the manual of the Beta SP UVW 1800 for any specific troubleshooting steps.
If none of the above steps resolve the issue, it may be a hardware issue and you may need to contact the manufacturer for further assistance. It could be a malfunction in the audio channel 1 input circuit or a problem with the internal signal routing. A qualified technician should be able to diagnose and repair the problem.
