Service Pack problem
VideoCam Suite 2.0
[Table of contents]
1. Notes about operating environment
2. Notes about operation
<><><> 1. Notes about operating environment <><><>
1. [Important] Adobe Acrobat(R) Reader 5.0 or later or
Adobe(R) Reader(R) 7.0 or later is required to
read the operation manual or the help information on your PC.
Get the license for using the operation manual before reading it.
2. AC adapters are recommended when using a notebook PC or
a HDD/SD video camera with the VideoCam Suite.
If a battery pack is used to power the HDD/SD video camera
or the notebook while recording or previewing motion pictures
or still pictures, they may not be recorded, previewed, or copied
to the PC Hard drive properly.
3. Standard configurations must be used for the fonts and
screen settings for Windows(R). Depending on the settings,
characters may not display properly.
4. It is impossible to use VideoCam Suite simultaneously with
other motion picture editing software or video capture products.
Note that this software may not function properly if software
with a timer recording feature in the background is running.
5. This software will function properly only when the system time
is set to a value within the following range.
From 0:00 on January 1, 1970, to 23:59 on December 31, 2037
If the system time is set to a value outside the range
listed above, the software may not start or function properly.
<><><> 2. Notes about operation <><><>
1. After installing/uninstalling the application, a dialog box is displayed
notifying the user that the system needs to be restarted.
Make sure to restart the system to complete the installation/uninstallation.
2. This software can handle only motion pictures and still pictures
recorded by this software or the Panasonic video camera
packed together with this software.
This software cannot process motion pictures and still pictures
recorded by any other video cameras, DVD recorders, software,
commercial DVD video, or commercial BD video.
3. User privileges for this software
- It can be used by only a user with administrative privileges
for Windows(R) XP and Windows(R) 2000.
- It cannot be used by the Guest users in Windows Vista(R)
4. While recording, if motion pictures cannot be recorded properly
for any reason, follow the procedures described in
the operation manual to restart the Windows system.
Motion pictures may not be recorded properly if any other
application software is used while recording the motion pictures.
Close all other application software and any resident programs,
such as virus scanning software. We recommend closing all other
applications and resident programs, such as virus scanning programs,
before starting this software. While recording motion pictures
on a DVD disc/SD card do not execute the following operation since
it may disturb proper recording and destroy the DVD disc/SD card.
- Turn off or restart the PC or DVD/SD
- Switch users or log-off
- Change the screen settings
- Use the power saving functions, such as the screen saver, sleep,
standby, and pause.
- Close this application by force
5. To record motion pictures on a DVD disc or an SD card,
check that the motion pictures can be recorded properly.
After checking that motion pictures are recorded properly,
delete the original motion pictures from the PC Hard drive.
6. When the edited motion picture is output in MPEG-2 format, some scenes
may not be generated completely in MPEG-2, and some parts of frames
may be shifted or omitted.
7. When motion pictures are copied from a DVD-VR formatted DVD disc
to the PC Hard drive, data other than motion pictures cannot be copied.
8. Do not modify or delete any files or folders related to
this software. Otherwise, the software may not function properly.
9. This software can only process DVD-Video discs recorded by this
software. This software cannot properly process DVD-Video discs
recorded by any other DVD authoring software.
10. This software cannot process motion pictures or DVD discs/SD cards
that are copyright protected.
- Microsoft(R) and Windows(R) are registered trademarks of
Microsoft Corporation in the United States and other countries.
- All names, company names, and product names used in this document
are the trademarks or the registered trademarks of their
respective companies.
