Connected but will not dim just turns on and off
SOURCE: leviton slide dimmer switch w/locator light light comes on but doesnt dim
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
SOURCE: I want to replace my
Some switches have a small area where you can insert a pin, or small screw driver that prsees down on the metal holding the wires and releasing them. Others do not have that and the wire must be cut and stripped.
