Blenders Logo
C
Carol Behrens Posted on Feb 27, 2014
Ninja stopped working
Ninja just stopped. Won't start or anything. Advise?
Mr Gadget
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 03, 2015
Mr Gadget
Contributor
Level 1:
Answers
Questions
0
Helped
1059
Points
0
Our Ninja 1100 also stopped during blending.
We set it aside and chopped manually.
Next day tried it again - it works.
Reason: motor probably has overheating protection. Must wait until motor cools down enough to re-start. So don't overload or overwork it.
Ninja Blender starts at low power and then stops when increasing the power?
That sounds like it is overheating. Does the red power light flash before it powers itself off? Units like this with an enclosed motor often have an internal fan as part of the motor and vents on the base to drive out the heat.
Various other ideas here and a link to Ninja Kitchen Support
https://www.google.com/search?q=ninja+blender+starts+at+low+power+and+then+stops+when+increasing+the+power
Oct 04, 2023 • Blenders
I purchased a Ninja blender 900 watts, great blender but disappointed to see it leaking after using a few times. Can the blender part be replaced. Regards Margaret Dunnington
Yes you can replace it for some kind of better device. I recommend you to check reviews about quiet blenders before purchasing some kitchen tools like that one.
Aug 25, 2019 • Blenders
Why won't the blender start? the on/off light keeps blinking
my Ninja blender wont turn on, power button keeps blinking red ...
https://answers.yahoo.com/question/index?qid...
Dec 11, 2011 - I know I"m not supposed to drown myself in the toilet yet the don't build in a head protector. The blinking light won't go off. It worked last night ...
Ninja Blender Red Light Is Flashing ' Appliance Repair ...
appliancerepairquestions.com/question/ninja-blender-red-light-is-flashing/
Mar 29, 2015 - My new Ninja Blender has a power button that is flashing red. ... and the top of the blender is on and secure but the light keeps blinking / flashing. ... How do I set the oven off from demo mode asked by Anonymous, 2 months ago ....Whirlpool MDU1955XTSS2 won't turn on asked by Anonymous, 4 months ...
cuisinart blender red light flashing but Questions & Answers ...
www.fixya.com > Forum > Tags
Not working
How to Fix a Blender ' DoItYourself.com
www.doityourself.com/stry/how-to-fix-a-blender
A food blender is a far less complex machine than most people might imagine. Because of this simplicity, you can easily determine the cause of a non-working ...
The Ninja Ultima Blender: What To Do When Power Light Is ...
? 0:36
https://www.youtube.com/watch?v=LfY_-VA5m8A
Oct 16, 2013 - Uploaded by Ninja Kitchen
... Blender start flashing. If the light on your Ninja Ultima Blenderis flashing, check the following... ... Still not working. Read more Show less.
Dec 09, 2015 • Blenders
Where do I find lids for the nj600 blender
Ninja Professional Blender . if this link works it will show the lid for the blender. If the link does not work, do a web search " Parts and accessories-Ninja. On the top menu, click on parts and scroll down to Ninja professional blender nj600 and click on it.
My ninja single serve won't start I put the container on it won't do anything
If the light on the power button is blinking, the single serve cup isn't fully engaged. Insert and twist clockwise to lock into position.
When using the single serve cup, the only blender button that will work is the pulse button.
5helpful
Blades on ninja blender won't spin, but motor seems to be working.
I don't have one, but inspect the shaft, it looks like there is a key on the shaft, then inspect the inside of the blade where it goes on top of the shaft, see if it looks like the shaft has spun out the blade and this is why it's not spinning.
Remove the blade and the container, then turn on and see if the shaft is spinning, it should be most are a direct drive.
So now if the shaft is spinning, that most likely means that the blade hole is broke where it sets on top of the shaft.
Look closely at the inside of the blade, you should see some type of damage like the groves are worn, I hate to see you buy one and it was the shaft that wore, but usually the blade will go first.
Mar 31, 2013 • Blenders
Did not get instructions or cookbook with my ninja KS1200?
I didn't get any instructions or anything with my Ninja either. You just kind of have to figure it out on your own. That's what I had to do. Sorry I couldn't help you out any more.
Jan 14, 2013 • Blenders
Top NINJA Blenders Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
john h
Are you a NINJA Blender Expert? Answer questions, earn points and help others
