This information comes from the online reference book: Using the Sound Menu
Use the remote to open the TV menu. Select the Sound menu, and the "speakers" decision. From the two choices, "TV Speakers" tells the tv to use its built-in speakers. "Audio System" tells the TV to use an external audio system, and disables the internal speakers. Select "Audio System," and check to see if it works. If it still hasn't recognized that there is an external audio system plugged in, you may need to clean the stereo mini jack (3mm audio jack) with a small wooden toothpick or similar small diameter non-conducting device.
Hi Lucus Keppel,
I selected audio system from the sound menu but i hear no sound, the tv speakers option do work however. I tried cleaning the audio jack with a thin ear bud, also tried to look inside the jack to see if there is anything that is blocking it, there is nothing, still cannot hear the sound through external speakers. I think it is recognizing the option "audio system" coz it stops the tv speakers when I select it, but somehow not able to send the audio signal through the audio jack port..
SOURCE: audio via hdmi
I had the same problem with the same configuration. In addition to the HDMI which is (DVD and Audio OUT only by the way) you need to connect the TV to the DVD through a high quality SCART cable as well. Remember to connect the SCART cable only while both the TV and DVD are switched off. To get the TV sound out of the DVD surround sound you need to click the FUNCTION key on the DZ230 remote a couple of times till you get the word TV on its screen, this is when you should hear the TV sound coming out of your surround sound as expected. Good luck.
SOURCE: sony bravia won''t play PS3
Try setting the resolution to a higher grade or a lower grade.. That solved the problem for me.. good luck!
SOURCE: Help HDMI Splitter Doesn't Work!
The HDMI splitter is intended to take one source to two displays. You need an HDMI switch to take two sources to one display, a device you can tell which input to select.
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Testimonial: "very fast, thanks for the help!"
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Hi Lucus Keppel,
