Model ZD300YO
Check to see if the fan is working. low or no air flow will cause it to ice up. may have to remove the front to de-ice. turn the unit off and slowly pour warm water over the coils to thaw. the water should drain right into the bin. also good to clean any dust off of the coils to keep the air flow open.
SOURCE: icing on front of dehumidifier while it is
You are operating it in an environment where it is too cold.
SOURCE: Zenith Model ZD300YO 30 pt
Take out bucket. Remove front cover two screws bottom left and right. Just inside lower left is a wiring harness with a clamp. Pry off and clean rust from clamp and tubing it attaches to. (if you put the bucket in and hold sensor between fingers the humidifier will start to work) Reattach clean sensor to clean copper tubing.
