This unit is about 3 years old and the low temp light would come on despite the temperature in the room being high. I could live with that as I just needed to switch it off and on again but now this light has started flashing continually whilst the unit is operating and I cannot get it to stop. There is nothing in the manual about it flashing!
De Longhi United Kingdom Home Contact delonghi customer support
Testimonial: "I've asked them and all they say is take it in to be serviced."
SOURCE: H20 POURS OUT OF THE UNIT BEFORE BUCKET IS FULL
It sounds like your unit is freezing up. Let it set for a day then set to run on the 3 hr cycle. Also rase the % of humidity to 60 or 65, and if it starts working lower the % setting in a few days by 5% increments until you get to the setting you want. Also read your owners manual troubleshooting section lots of good tips.
Jimh32851
SOURCE: Hampton Bay Dehumidifier Model# HB50
MY dehumidifier leaks water from upper part of unit causing water to leak on floor while running.
SOURCE: fan runs, no water collected
possible compressor problem or coolant leak.
Coolant system warranty is usually more than 1 year- check your warranty.
SOURCE: I have a 50 series
If the humidity level is at or lower than 30%, the unit won't turn ON, until the reaches 35 - 40%. It's rare for the sensors to go bad. Just keep in mind, the dehumidifier is reading the humidity near the floor, not up at say, chest level. Humidity levels change every season, so this really would not be that unusual. Make sure that your clean the air intake filter regularly. Cleaning and wiping down the coolant coils would be a good idea, too..
Hope this helped you. Please let me know.
SOURCE: Dehumidifer FDD40J6, probably 10 years
The problem lies in the way the bucket is reinstalled or the float valve (if yours is so equipped) is stuck in the UP position.
Remove the bucket for it's holder and check for the float valve. If it is stuck in the up position, jiggle the arm to make it return to the down position. Be fore you reinstall the bucket, look at the back wall of the bucket holder. There you will see a trigger switch. It's the bucket safety removal switch. Check it to make sure it's still intact. At 10 years old it may have broken OFF. If it appears to be be intact, install the bucket "squarely" into the bucket holder from top to bottom. Being sure that it makes firm contact with the bucket safety removal switch. When installed correctly, the bottom of the bucket will not tilt down at all.
Also, check the air intake filter as it may be dirty of clogged.
Hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
