The dvd player is not playing in color either......please help!!!! The direct tv box is just a standard box with no hdmi just rca cables ( yellow,white and red)
You may have a bad box. Contact support from direct tv
Testimonial: "I have spoke to direct tv and they ran tests on their end and say the issue is not with direct tv......maybe with the tv itself???"
SOURCE: dvd won't play through PACE hi def converter box, service electric cable ty
Why are you running hdmi to converter box? Run HDMI cable directly from dvd to new Panasonic plasma. The less things in between, the better the picture.
SOURCE: DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
SOURCE: I'm simply looking for the
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
SOURCE: Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
SOURCE: Television is not recognizing HDMI inputs
there is a possibility that there might have been a power surge sent over hdmi into the hdmi board on the tv. if on your model the hdmi board is seperate from the sine board then youll have a cheap replacement if not its gonna cost you roughly 300-400 is my guess.
call your repair guy
Makes no sense. To break down where the trouble is coming from try hooking the DVD player directly to the TV and see if there is color. If not then it is the TV. Make sure you have the TV on the correct channel for modulation when hooking up the dvd player ie (3 or 4)
