Question about Motorola Mobility Rival A455 Cell Phone
Can't hear the person calling me
I can't hear the person talking to me on the phone. They can hear me just fine, but I can barely hear them. I am not old, hard of hearing, or wearing a hearing aid. The phone is probably getting old though...
  • Official Brand Answer
  • 3,100 Answers
Sounds like your speaker has failed. Please contact Verizon for assistance.
Posted on Jun 02, 2014
SOURCE:
SOURCE: can't hear caller
I expierenced the same problem with my V265 phone. First, note that performing this repair as I did will most likely void any warranties on the phone, and also is an electrical shock hazard. This repair should only be performed if the person/s performing the repair understand these risks and have at least basic technical knowledge in circuits, electricity, and audio. I take NO RESPONSIBILITY for damage or injury in any way, shape, or form. Please to prevent errors or any more damage, read directions fully before starting this repair. - Remove the Battery and make sure no chargers, headsets, etc., are currently plugged into phone. - Remove the housing on the phone which is on the same side of the camera and the external display by gently and carefully prying, making sure not to break the latches or any of the external parts. - Using a Torx bit (I believe it was either a T15 or T20 I used but not sure) or a small flat head screwdriver, remove the 4 screws holding down the board. - Now examine the speaker located at the earpiece of the phone and the two contacts which are on the board you just removed. Look to see if they were properly alligned and if contact is being made between the speaker and the board. (a PINK pencil eraser works great as a cleaner for circuit board contact points) - If contact is being mad and no obvious obstruction is found to prevent contact with the two, the easiest way for me was to take a speaker from another phone, and using it in place of the old one. (If you are willing to use extra time, you could also try finding an actual replacement from a manufacturer.) - I used a speaker from a motorola phone which was actually a few years older than my V265. - After finding a replacement speaker, you'll need to use some trial and error to properly allign it with the contacts on the board and to make it stay in position during everyday use. - For my V265, I had to use a razor and shave away the plastic molding which held the old speaker in place. Then use a VERY small amount of super glue to hold the speaker in position. Then I used a little bit of hot glue to give it some flexible strength. All together, it took me about 1 hour to complete this task and start using my phone again normally. - If any additional assistance is needed, feel free to e-mail at spike8551@comcast.net leaving your name and prefirably a phone number and best time to call, as a return contact. This will make it easier for me to help the best I can. Thank you and good luck.
Posted on Dec 21, 2006
Bogdan
  • 198 Answers
SOURCE: Callers can't hear me speak
This is because the microphone in your phone got disconnected in some way. Probably a faulty contact. This is a known fault for some motorola phones. The solution would be to go to a service center and ask them to check your microphone. It isn't an expensive repair at all. They will be able to do this for you in about half hour or so. It is the safest way to do this, otherwise you will have to dissasemble the phone yourself and check the microphone.
Posted on Mar 14, 2007
NickBeamAA
  • 53 Answers
SOURCE: Can't hear caller
The earpiece speaker has gone bad. Unless you have access to a replacement speaker and can solder you will have to take the phone to you nearest Motorola service center.
Posted on Sep 06, 2007
nasirahmed
  • 282 Answers
SOURCE: incoming call
Seems your ear speaker has a problem. It need to be changed.
Posted on May 27, 2008
  • 100 Answers
SOURCE: When I make a phone call I cannot hear anything.
check and replace the earpiece speaker
if not try to rework the UEM
Posted on Oct 15, 2009
Testimonial: "Thanks!"
When im no the phone i can barely hear the other person. Unless im on speaker phone then i can hear fine
maybe by mistake you reduce the volume on the iphone.
try the following during a call press on the right control up volume to see if that improve your sound.
if that doesn't work you should go to an apple store or your cell provider.
Dec 21, 2011 | Apple iPhone 4 Black Smartphone
Our line one cuts out even when we're talking on it & we can just barely hear the person on the line but they can hear us clearly. We have unplugged the phone's power cord & plugged it back in...
I have the same sort of problem...kinda..lol. My Vtech sorta 'cuts out' when there is noise at my hosue. The person I'm talking to can still hear me but I can't hear them. If my son starts crying or there's any other loudish type noises on my end, it's like the phone is trying to cutout my background noise, but all it's cutting out is the person talking to me. It's not that the noises in my house are loud and I jsut can't hear the person I"m talking to, b/c if i cover the mouth peice then no matter how loud the sound in my house is i can still hear the person i'm talking to but I HAVE to keep the mouth peice covered. It's really annoying!
Nov 15, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
I barely hear the person i am talking to is there a way to turn up the volume on the phone
Yes you can turn up the volume,While on call press right navigation key to increase the volume and left navigation key to reduce volume.
Thank you
Nov 12, 2010 | Nokia 6030 Cellular Phone
The sound is suddenly very quiet.
this phone has many different volumes to play with, one of them is the volume for, when your calling someone, simply, when you call someone, press the volume up button, and you should hear the person louder
Oct 21, 2009 | Samsung Propel A767 Cell Phone
I have tinnitus and I can barely hear the person who called.
The ear piece is out of order.Just replace it u'll be satisfied.
Sep 23, 2009 | Cell Phones
Can't hear who I'm talking to.
unlock the cover but you must have t6 screw driver
and clean the net if still you
must change the earpiece
May 06, 2009 | RIM BlackBerry Curve 8310 Smartphone
The phone doesn't work
what is ur model no brand
Jan 28, 2009 | Lands Phones
Can't hear caller but caller can hear me except on speakerphone
Take the phone to a mobile reapir center and hvae them replaced teh ear piece and also the speaker.
Oct 18, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Incoming call
May 27, 2008 | Motorola Mobility RAZR V3
Sony ericsson Z520
I had the same problem with that phone... while manipulating the mobile part (cover) you can slightly improve the volume.
Another point to check is the button on the side of the phone which allows to increase or lower the volume: it could happen that you turn the volume low without noticing it...
My solution was to replace the phone.
Jan 02, 2008 | Sony Ericsson Z520a Cellular Phone
Motorola Mobility Rival A455  Cell Phone Logo
120 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
