Computers & Internet Logo
G
Geneva Malagutti Posted on Feb 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Set ethernet I just set up the phone and it can make outgoing calls but does not receive incoming calls. I have a regular phone hooked up next to it and when I call the number it rings on the other phone
Dayton Computer
Level 3:
  • Master 1,640 Answers
  • Posted on Feb 26, 2014
Dayton Computer
Master
Level 3:
Answers
1640
Questions
0
Helped
819094
Points
6396
Transmission circuit is responsive, however the speaker seems to be defective or the receiver section has failed. This is an internal function whereby the unit requires inspection by a technician to correct the issue at hand.
3 Related Answers
Anonymous
  • 6 Answers
  • Posted on Oct 20, 2008
SOURCE: The phone does not ring
I know this is not a answer to the problem.
But for Logitech to say it's a Vista 'issue' is rubbish, Vista has been out for too long now to be blamed for them being lazy or disinterested.
Can I have a refund?
Anonymous
  • 36 Answers
  • Posted on Apr 30, 2009
SOURCE: Philips VOIP8411B/37 IP Phone - Cannot make outgoing Skype calls
the internet connection's outgoing is too slow. ALl internet connections have an outgoing and an incoming speed. Make sure you are not uploading anything to the internet or get a faster internet service provider
Anonymous
  • 192 Answers
  • Posted on Sep 19, 2009
SOURCE: mitel 5212 no dial tone and goes straight to voicemail
Not too sure about the no dial tone issue, but you can check to see if the DND is turned on...
Press the Blue Superkey and scroll thru till you see DND (Do Not Disturb) is on and shut it off.
I-DECT Phone. It receives incoming calls but won't dial outgoing.
Question edited fir clarity
Ideas here. You can also Google
make model manual
See if it is a an outgoing call barring feature.
https://www.google.com/search?q=I-DECT+Phone.+It+receives+incoming+calls+but+won%27t+dial+outgoing
2answers
I can not call or receive calls. She says she dropped it but i think she went in the settings and changed to so that she can not receive or make calls by mistake. what is wrong
She might have barred the phone.
This is what to do. Press this code #330*0000# and send. Your will be unbarred.
Regards
Jul 05, 2011 • Cell Phones
4helpful
2answers
My nokia phone can neither call nor receive acall,,its barring codes are blocked
I am sure this solution will help you, Just follow the steps.
1- Go into the settings and find the option of call barring usually its in call settings option. 2- Then you find the option of deactivate barring on all outgoing & incoming calls select yes and if it ask you any code or password then its 0000 by default or your sim pin code if you haven't changed. 3- After deactivating barring of incoming and outgoing calls, your phone can make and receive calls.
May 22, 2011 • Cell Phones
2answers
Nokia n73
Please make sure your outgoing and incoming calls are not barred.
go to settings
go to call settings
go to call barring
and check the status of your outgoing and incoming calls.
There is also a line 1 and line 2 facility. Make sure you are using Line 1
Hope the above is helpful.
Thanks,
Kanu
2answers
I9+ phone will not receive incoming calls
check and make sure you ringer is set to something but silent.
Jun 04, 2009 • Cell Phones
1helpful
No connection outgoing and can't answer incoming calls
I unpluged all hand sets for an hour,when I reconnected the hand sets they worked fine.
2answers
Call barring
Use the network services menu for this...
Use this menu to access network services. Please
contact your service provider to check their availability and subscribe to them, if you wish.
This network service allows you to restrict your calls.
1. Select a call barring option:
All outgoing: prohibit outgoing calls.
International: prohibit international calls.
International except home: only allow calls
to numbers within the current country when
you are abroad, and to your home country.
All incoming: prohibit incoming calls.
Incoming while abroad: prohibit incoming
calls when you use your phone outside of your
home country.
Cancel all: cancel all call barring settings,
allowing to be sent and received normally.
Change barring password: change the call
barring password obtained from your service
provider.
2. Select the type of calls to be barred.
home country.
provider.
if you have any queries about your mobile..you can have a look at this user manual which can be downloaded from
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-D600-_E
hope this helps :)
Top Polycom Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
