One For All URC-6131 Remote Control Logo
B
Buster Williams Posted on Feb 26, 2014
Universal Romte & Roku
Does One For All have codes which control a Roku box?
1 Related Answer
Anonymous
  • 6 Answers
  • Posted on Aug 24, 2008
SOURCE: RE: Emersom Universal Romte
goto this website this will help
http://www.thompsontv.com/rcarc.html
Need codes FOR GE UNIVERSAL RC 24914-D TO CONNECT MY roku express
Yes, you can use a GE Universal Remote RC24914-D to set up your Roku Express box. To do this, you'll need to find the correct code for your Roku Express device and program it into the remote. Here's how:
  1. Turn on your Roku Express device.
  2. Locate the "Code Search" button on your GE Universal Remote. This button is usually labeled "Code Search" or "Setup."
  3. Press and hold the "Code Search" button until the indicator light turns on.
  4. Enter the code 9-9-1. The indicator light will blink twice.
  5. Point the remote at your Roku Express device and press the "Power" button. If the device turns off, you have found the correct code. If it does not turn off, repeat steps 3 to 5 with a different code until you find the correct one.
  6. Once you have found the correct code, press the "Code Search" button again to save the code.
The codes for the GE Universal Remote RC24914-D can vary depending on the version, so it's possible that the code 9-9-1 may not work for your device. If that's the case, you can try other codes listed in the remote manual or on the GE website.
I hope this helps you set up your Roku Express device using your GE Universal Remote.
I have a onn Roku TV that I need the programming code
Remote Control Codes For ROKU TVs with setup instructions
www.directutor.com > content > remote-control-codes-r...
Roku remotes simple interface revolutionize your TV, adjust the volume, mute, control your streaming with one roku remote and voice search ... Instructions for Roku TV remote code programing using Universal Remote. ... Cable Provider: ONN. GE Universal Remote Model 24922: 2891
Remote Brand: Remote Codes for TCL Roku TV ...
ONN: 3851
RCA/Voxx: 12434,387, 12049
I need the romte contol code from this unit so I can proigram it in a Philips Universal remote.
0281,0275,0229. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name only of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
How do i get the code for vibe axcess 5 in1 to work roku player
Universal Remote codes for Roku
where do i enter my code # ,for my roku ,trying to do this for a hour
I git a silvercrest universal romte for a thomson tv an i need the code
Check this code. 1056
For more codes with other remote controls, check this link.
2answers
Codes for a universal remote
Roku is a streaming player; it streams many types of data like comedy, TV shows, horror, etc. Many users had admired to use the Roku because of its comfort and easy to use. The Roku Universal Remote code Comcast is used to control your entire device.
    ·Roku Universal Remote is programmed to access different devices like as TV, DVD, and VCR player. It is a more interesting that you can control your entire device in your single remote.
    ·This remote control is used to control the audio and video of any brand of your device.
    ·This code is identifiers for configuration of your device.
    ·There are two code lists they are CL3 and CL4. Check this code list to replace your batteries and cover.
    ·You can execute your device in 2 methods
    1.Auto programming
    ·Use the universal remote to turn on your device.
    ·Then press "Setup Release" till TV button flashes.
    ·Enter the digit and choose the code to setup your device.
    2.Manual Programming
    ·Use Comcast remote, if you want to program then you can use Aux KEY.
    ·Check the instruction for manual and start entering the code. First ensure that you have a Roku account or else get it from the Roku.com/link. For details contact@ +1-844-965-4357.
1-rokuactivationcode-com-roku-universal-remote-code-comcast-blog-433sdnpnckpfjmjifzsr4nnb-5-0.jpg
4helpful
2answers
What is the code for Roku in GE universal remote
I'm looking for the same thing. So far I haven't found a code that works.
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
