M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.1-Press utility button on panel.2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.3-its the code to get into service mode.4-After pressing above mentioned buttons you will enter into service mode.5-Now select service choice option.select it by pressing OK button.6-In service choice option you will see Maintenance count option.7-Select it by pressing Yes or OK button.8-There will be three options 0,1,2.9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
Konika Minolta BizHub 163 - Error Code M2
Press the Utility button,
then Stop 0 0
then press again Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
Resetting the maintenance code display: 1.Entering the Tech.Rep.Mode Procedure a) Press the Utility key. b)Touch Meter Count. c)Press the following keys in this order : Stop - 0 - 0 -Stop - 0 - 1. d)Select Tech.Rep.Mode. 2.Resetting the maintenance code: M2 Waste toner box Resetting procedure: a)Enter the Tech.Rep.mode. b)Select "Counter". c)Select "Consumables". d)Select the count of waste toner. e)Press the clear key. M3 Oil web roller.
I Have a Konika Minolta bizhub 211. I had been trying this solution for repairing m2 call. but the code is appear till now. anyone help me. please give me solution step by step. Thanks
Hi You can reset (M2) by reset clear data Enter to service mode By Pressing : Utility - clear -0 - 0 - clear -0 - 1 Press ADJUST Press CLEAR DATA Turn OFF Copier and Switch it ON
Remove the six screws on the back cover. After the batteries are installed you need to reset the board. There is a little reset area that needs to be shorted to get the calculator back to normal. Look closely at the circuit board- You'll see a little circle next to the word reset. Its near the middle of the board. Wet your finger- press it on the circle. It should short. Blow it dry with your breath. It should work...
