First, when there is one problem many things will adjust to maintain drive ability with out hurting the emissions system setting many codes. Repair the #6 miss fire and erase all the codes and see if any come back. Or just erase all the codes now. If the check engine was not blinking then the miss fire is not a real bad problem now and will not set again until it reads the miss again.
Your caption says misfires at high, then you say low? You have a 95. Lots of miles I assume. So there are several things that would cause misfires at high and low. First is timing chain/belt, sloppy. Second, would be the valves and rings. Valves worn or bent, not seating right. rings just worn out, not holding compression. Do a compression test and see. Low speed or idle misfires can be from vacuum leaks. check hoses. Low and high rpm misfires can be from ignition problems. Wiring, coil/s, ignition modules.
You may want to check for fuel volume and fuel quality. There may be moisture in the fuel. It would also help to know which cylinders it is misfiring on. Scan tool will show the misfire on live data.
When you change the crank sensor you need a scan tool to set them.The distributor has to be turned using a scan tool to get the crank sensor dialed in.
If your car is miss firing and your husband changed the coil packs,the wires leading from coil packs to sparkplugs must have got crossed.This will change car timing which will result in the car miss firing.He needs to go over wiring and correct problem for car to run right.You can go online to autozone.com and type in Info about car to get the correct wiring layout.Your problem isnt the new plugs n wires.Its the wiring layout.
the engine miss fire can cause the other codes to set. you need to repair the miss fire and clear all codes after the miss is repaired then see if the 02 sensor codes return. the miss fire is probably a bad spark plug wire a good tune-up should take care of it ........HAVE A GREAT DAY
