Whirlpool RF368LXKS Electric Kitchen Range Logo
A
Anonymous Posted on Feb 26, 2014
DID NOT HAVE OVEN CLEANER ON BUT LOCKED - Whirlpool RF368LXKS Electric Kitchen Range
Oven cleaner, door lock problem gave error reading F9, door locked, won't open, not cleaning.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Turn knob to oven cleaner and locked oven door...Now will not open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
heatman101
1helpful
2answers
"Door locked" indicator light on, but able to open/close oven...
Unplug the stove. Remove the oven control plug and check between the 2 pins going out to the door lock mech if the meter reads open circuit the door lock switch is bad. If the meter reads continuity then the oven control is bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
2answers
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
Lock on oven is locked and door open
look towards the center of the door, next to the "self clean latch" youll see a thin metl "plunger", try pressing this in and then restarting a clean cycle, then quicklly cancel clean it should reset the lock/latch mechanism
Locked door light flashing
I had the same problem with a gas kenmore oven. I played with the lock mechanism (opened it a little more manually) and it fixed the problem...
1helpful
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
1helpful
Locked door on self cleaning oven
try unplugging the stove for some minutes and plug back in.
1helpful
2answers
Hotpoint self-cleaning oven
  I believe they make an oven cleaner for self clean ovens.  Don't try regular oven cleaner.  Ruins finish.
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
